Mancava il topic generale per questo controller che sarà presto disponibile in Italia, il nostro scarabokio aka RU.DiJ ne riceverà presto un esemplare direttamente dalla EKS!
Eks - Otus
Compatibility:
ASIO
Core Audio
Compatible with any software that supports MIDI learn
USB2.0/USB1.1
Win/OSx/Linux
Controls:
High resolution 7.5" wheel with touch sense (position/speed LED indicated)
4 jog dial type controls with switch
17 low travel buttons
6 touch buttons
10 assignable control knobs
Built-in touchpad/assignable X/Y control surface for mouse or effect control
80mm touch sensitive pitch slider, with position LEDs
All controls LED backlit
Audio interface:
Integrated 24-bit 6ch audio interface
16bit/24bit, 44.1kHz/48kHz
Frequency response 4Hz-24kHz
SNR >115dB JEITA (a-weighted)
THD+N 0,002%
2 x Burr-Brown I2S DAC
2,5V RMS (7Vpp)
Connectors:
USB
4 x analog out RCA (two stereo outputs)
2 x out (spdif)
6.3mm headphone output
Dimensions:
365mm x 335mm x 70mm
Weight 2 kg
Power supply:
USB powered (450mA)
Eks - Otus
Compatibility:
ASIO
Core Audio
USB2.0/USB1.1
Win/OSx/Linux
Controls:
6 touch buttons
Audio interface:
THD+N 0,002%
2,5V RMS (7Vpp)
Connectors:
USB
2 x out (spdif)
Dimensions:
Weight 2 kg
Power supply:
USB powered (450mA)
Altri video http://eks.fi/product.php?p=products&id=55
Tutte le info: http://eks.fi/product.php?p=products&id=34
Posted Wed 24 Sep 08 @ 6:37 am
