Mandare un PM a TexZK..... no eh ? ;))
Buon mix da Max....'(-_-)'
Posted Mon 12 Apr 10 @ 5:50 pm
NEW AUDIO-EFFECT
Segnalo l'uscita del nuovo "Long Start" creato da DJCEL.
>>> http://www.virtualdj.com/addons/11155/LongStart.html
Description:
Turntable Start effect
byez,
Gabriele DiJ
Description:
byez,
Gabriele DiJ
Posted Mon 19 Apr 10 @ 2:39 pm
Gabriele sei sicuro?
Scusami ma andando al link dice che è stato in serito il 10/04/2004
Posted Tue 20 Apr 10 @ 5:00 am
Date added: Sun 04 Apr 10 @ 6:29 pm
Last update: Sun 04 Apr 10 @ 6:29 pm
Posted Tue 20 Apr 10 @ 5:06 am
il mio dubbio nasce dal fatto che andando alla pag. effetti audio
allo stesso dice creato per Virtualdj 4.1
Posted Tue 20 Apr 10 @ 7:24 am
Probabilmente funziona a partire da Virtual DJ 4.1
Posted Tue 20 Apr 10 @ 7:39 am
E' stato aggiornato il "Sampler Manager" ora compatible con Virtual DJ 6, mi pare abbastanza intuitivo da usare e funziona pure! :)
http://it.virtualdj.com/addons/1046/Sampler_Manager.html
Posted Tue 04 May 10 @ 5:19 am
NEW AUDIO-EFFECT
Uscito il nuovo Filters v2.0 creato da TexZK.
>>> http://www.virtualdj.com/addons/4294/Filters.html
Description:
A comprehensive suite of audio filters, useful for live handling.
Features:
_ Filter type selection: Low-pass, High-pass, Notch, Automatic (aka «Wah-Wah»)
_ Cutoff/center frequency slider, modeled on the filter type
_ Resonance (Q factor) slider, modeled on roll-off and frequency
_ Roll-off selection: -12, -24, -36, -48 dB/oct (extreme!)
_ LFO with added depth and length parameters
_ Quantizable LFO loop length
byez,
Gabriele DiJ
Description:
Features:
byez,
Gabriele DiJ
Posted Mon 19 Jul 10 @ 6:14 pm
NEW AUDIO-EFFECT
Uscito il nuovo Gates v1.0 creato da TexZK.
>>> http://www.virtualdj.com/addons/11858/Gates.html
Description:
Gate effects, which modulate the sound (on/off) with different shapes and sweeping noise.
Features:
_ Quantized gate period between 1/4 and 1/32 bars
_ 3 seamless morphed shapes: square wave (duty cycle 15% to 50%), square wave with decay, and pure decay
_ Additional noise for gate frequency sweeping effects
_ Optional fixed beat alignment and muted input
byez,
Gabriele DiJ
Description:
Features:
byez,
Gabriele DiJ
Posted Fri 13 Aug 10 @ 7:53 am
NEW AUDIO-EFFECT
Uscito il nuovo Reverb v1.0 creato da TexZK.
>>> http://www.virtualdj.com/addons/11861/Reverb.html
Description:
Reverberation effect.
Features:
_ Dual Dry/Wet behavior: 0-50% controls the reverberation amount, 50-100% controls the freezing amount
_ Room size, from small room to very large hall - NOTE: there's no "timeshift" effect
_ Reverberation (feedback) high-pass filter
_ Reverberation (feedback) low-pass filter
byez,
Gabriele DiJ
Description:
Features:
byez,
Gabriele DiJ
Posted Fri 13 Aug 10 @ 2:32 pm
Ho corretto alcuni problemi sonori gravi nei Filters v2, ora in versione v2.1. Ora suonano molto simili ai classici filtri per DJ, come quelli degli Xone e dei DJM.
Come solito, consiglio a tutti di aggiornare alcuni componenti di Windows per far funzionare alcuni plugin aggiornati di recente.
L'ultima versione delle librerie Visual C++ Run-Time attualmente disponibile (12 aprile 2010) è la seguente:
http://www.microsoft.com/downloads/details.aspx?displaylang=it&FamilyID=a7b7a05e-6de6-4d3a-a423-37bf0912db84
Non farebbe male aggiornare anche le DirectX:
http://www.microsoft.com/Downloads/details.aspx?familyid=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=it
Posted Sun 15 Aug 10 @ 8:54 am
UPDATED AUDIO-EFFECT
Aggiornato l'Echo Out di macourteau.
>>> http://www.virtualdj.com/addons/661/EchoOut.html
Description:
digijoc-mele's idea. This is the same as LoopOut, except that the music keeps playing, which creates a sort of beat-aware echo.
Update:
2010/09/23
Updated to use the VDJ5 API instead of the VDJ2 API, and also created a Mac version!
byez,
Gabriele DiJ
Description:
Update:
2010/09/23
byez,
Gabriele DiJ
Posted Thu 30 Sep 10 @ 1:36 pm
Scusate se lo posto qua..ma un plug in compressore e limiter che funzioni come si deve non c'è ?
ciauz
Paolo
ciauz
Paolo
Posted Thu 30 Sep 10 @ 2:57 pm
NEW AUDIO-EFFECT
Uscito il nuovo Echo Doppler creato da TexZK.
>>> http://www.virtualdj.com/addons/12067/EchoDoppler.html
Description:
Echo effect with morphed depth.
Features:
_ Dry/wet slider, allowing for full dry (no feedback) and full wet (pure feedback)
_ Morhped depth, for extreme live delay shaping, swinging from a few milliseconds (flanging effect) to 1 second delay
_ Feedback control, up to 100% feedback (for pure feedback looping effect), with a limiter to avoid signal saturation
_ Feedback high-pass filter, to reduce dry signal compression and get a lighter echo effect
_ Beat and half beat delay presets
_ Additive and subtractive feedback, especially useful for flanging effects
_ Support for "ping-pong" effect for deeply wide stereo signals
byez,
Gabriele DiJ
Description:
Features:
byez,
Gabriele DiJ
Posted Tue 05 Oct 10 @ 7:37 am
NEW AUDIO-EFFECT
Uscito il nuovo Filters High&Low creato da TexZK.
>>> http://www.virtualdj.com/addons/12075/Filters_High_Low.html
Description:
High-pass & low-pass combo filters.
Features:
_ High-pass filter from 10 Hz to 8 kHz
_ Low-pass filter from 150 Hz to 21 kHz
_ Resonance slider
_ A simple limiter to reduce saturation - NOTE: clicks and glitches are NOT completely avoided with high resonance!!!
_ Support for "extreme" cutoff (-48 db/oct)
byez,
Gabriele DiJ
Description:
Features:
_ Resonance slider
byez,
Gabriele DiJ
Posted Wed 13 Oct 10 @ 2:32 am
ciao ho acquistato una mp3 e2 usata chi me l'ha venduta ah gia registrato il codice come può fare per farmi usufruire del codice?
Posted Wed 13 Oct 10 @ 7:19 am
perdonami ma cosa c'entra il tuo problema con gli effetti audio?
contatta l'assistenza per queste questioni :
http://it.virtualdj.com/contact/index.html
Posted Wed 13 Oct 10 @ 7:25 am
Rilasciato il nuovo NoiseBell v1.0 creato da... me :-)
>>> http://www.virtualdj.com/addons/12202/NoiseBell.html
Description:
Bell-shaped noise effect, with echo.
Features:
Note per gli utenti Windows:
In caso non funzioni, ricordarsi di aggiornare le librerie di sistema MSVCRT:
>>> http://www.virtualdj.com/homepage/TexZK/blogs/4265/Windows_libraries_for_plugins.html
Description:
Features:
- Dry/wet slider to set the input gain (echo still plays at full volume)
- Filter center frequency slider from 50 Hz to 8 kHz, with fades at the very ends
- Resonance slider to choose between an harsh noise and a sweet narrow-band sound
- Echo feedback slider
- Beat or half-beat echo length
- Ping-pong (stereo) or mono echo output
- Pink (default) or white noise
Posted Thu 11 Nov 10 @ 5:21 am
NEW AUDIO-EFFECT
Uscito il nuovo FlanJet creato da TexZK.
>>> http://www.virtualdj.com/addons/12303/FlanJet.html
Description:
Flanger effect with manual Jet or LFO.
Features:
_ Feedback slider
_ Flanger delay depth (added delay)
_ LFO length slider
_ Base delay slider
_ Stereo effect slider
_ Manual "jet" switch
_ Quantizable LFO
_ Additive (default) or subtractive feedback
byez,
Gabriele DiJ
Description:
Features:
_ Feedback slider
_ LFO length slider
_ Base delay slider
_ Quantizable LFO
byez,
Gabriele DiJ
Posted Tue 30 Nov 10 @ 1:38 pm
NEW AUDIO-EFFECT
Uscito il nuovo TalkFilter v1.0 creato da TexZK.
>>> http://www.virtualdj.com/addons/12617/TalkFilter.html
Description:
Simple formant filter with echo
Features:
_ Dry/Wet slider
_ Vowel selection slider: U-O-A-E-I
_ Filter echo depth
_ Single or half beat echo
byez,
Gabriele DiJ
Description:
Features:
_ Dry/Wet slider
_ Filter echo depth
byez,
Gabriele DiJ
Posted Tue 01 Feb 11 @ 2:09 am
