Filter Name - UK No1
Filter String - comment contains "UK No1"
Filter Name - My Mixes
Filter String - comment contains "Mymix"
* You can name the filters what ever you want - I just used what you were looking for...
Have fun....
Have fun....
Posted Tue 11 Sep 07 @ 2:08 am
Thanks cstoll, works a treat on "Mymix", although UK No 1 is not as successful. In the comment field is is written like this - (UK No 1), when I type that in, it gives me a syntax error!?
Would be great to be able to pull up all the UK No 1's in this way.
Posted Tue 11 Sep 07 @ 2:29 am
Ok, well your example originally didn't have a space in between 'No' and '1'. Also, when using multiple words you have to use the Quotes. I wrote the examples as you should have typed them or copy and paste them. So here is the corrected one based on your info. And, I tested it...
Filter Name - UK No 1
Filter String - comment contains "(UK No 1)"
Posted Tue 11 Sep 07 @ 2:53 am
Of course, originally I was just throwing my thoughts in the air! I don't know too much about syntax, but I just tried your suggestion with the quotes and It works fine. I now have a very tidy list of all the UK No 1's. Very handy!
These filters are just awsome!
Thank you cstoll, you are without doubt one of the most attentive and helpful users here. Dave.
Posted Tue 11 Sep 07 @ 3:14 am
Songs under a certain time range.
For example, this filter will show songs under three minutes excluding songs that have a zero length.
songlen<180 and songlen !=0
Song length is in seconds. You could also add an argument to filter songs that are less than 10 seconds, etc...
P.S. There needs to be more of an explanation of the different variables used like songlen. I had to play with it a little to guess that it used seconds.
Posted Mon 17 Sep 07 @ 1:20 am
Is there a filter that separates BPM's with the star from those without?
Posted Tue 18 Sep 07 @ 3:06 pm
No, none currently. How ever possibly a new feature for a future release.
Posted Tue 18 Sep 07 @ 4:02 pm
Keep this as a sticky. Maybe more people will contribute...
Posted Sat 29 Sep 07 @ 10:57 pm
is there a way of listing top 50 most played cons
Posted Wed 03 Oct 07 @ 7:55 pm
What is a 'cons' ?
top 50 nbplay < gives you the top 50 played based on the number of times you have played each track.
Posted Wed 03 Oct 07 @ 8:51 pm
How do we do Karaoke? I know that might be a stupid questions but I did not see it in this post anywhere.
Thanks.....
Thanks.....
Posted Thu 13 Dec 07 @ 10:39 am
Umm...sorry...
type=karaoke
type=karaoke
Posted Thu 13 Dec 07 @ 11:03 am
filter: filename contains ".mp3"
filter: filename contains "."
name: 70's and 80's
filter: year>=1970 and year<1990
filter: comment contains "mainstream" or comment contains "promo"
filter: genre contains "specific genre"
name: 70's and 80's
Posted Fri 14 Dec 07 @ 9:25 pm
how do i separate the beat of song from the vocal seen like i can do it with virtual dj 5.0
Posted Tue 22 Jan 08 @ 7:27 am
Almost impossible without very high end software. Try get the instrumentals from singles.
Posted Tue 22 Jan 08 @ 7:40 am
Is there a way to filter tracks that does NOT contain something? For example I have a track which genre is "pop;ballad"
and i want to filter tracks which genre is "pop" but not ballad, is it possible?
i tried:
"genre contains pop and !(genre contains ballad)" but it has syntax error.
i tried:
Posted Tue 22 Jan 08 @ 8:03 am
NICE!
Posted Thu 24 Jan 08 @ 12:35 pm
Thanks all for the nice infos, so i don't need to reorganised my folders. The filter foulders is an amazing option!
Posted Sun 16 Mar 08 @ 9:35 am
I have videos sorted by year. They are then broken down by type. The filepath would look like this (D:\PO HV 2006\rock\) What filter can I use to show just the rock folders from all the years? Thanks.
Posted Thu 24 Apr 08 @ 11:24 am
(filepath starts with "D:\\PO HV")and (filepath contains "\\rock")and (type=video)
Copy this as is and use it.
Posted Thu 24 Apr 08 @ 1:53 pm
