blaide13 wrote :
...... Then I repeated this process again on the 2 right deck buttons.....
PitchBend - on the left side and PitchBend - on the right side is actually the same button. You need to assign the action JUST ONCE, it doesnt matter which button you will chose (left side or right side)
So, 1 action for BOTH pitchbend- and 1 action for BOTH pitchbend+
You may also have to assign your controller to Left-Righ (default).
Posted Mon 25 Oct 10 @ 3:59 pm
OK i got the code working but there is a tweaks i want in the script but I don't know how to do make it
here's the code I used:
I want want to happen is that when deck 3 or deck 4 is the active deck the master tempo led should be lit on my board the mastertempo is tied to the beatlock button and the beatlock led
btw I have a DJ Control MP3 if you need a reference
device_side 'left' ? deck 1 leftdeck ? deck 3 leftdeck & deck 3 select : deck 1 leftdeck & deck 1 select : deck 2 rightdeck ? deck 4 rightdeck & deck 4 select : deck 2 rightdeck & deck 2 select
Posted Mon 25 Oct 10 @ 6:08 pm
Syntax for the LED..
but this LED will not work otherway, no beatlock or mastertempo sign.
device_side 'left' ? deck 3 leftdeck ? on : off : deck 4 rightdeck ? on : off
Posted Mon 25 Oct 10 @ 6:22 pm
DJ Homeboy wrote :
Have you installed a new custom mapper for it from the site? If so remove it from the devices folder and re-launch VirtualDJ. Is it recognized?
pepesicatdizon wrote :
Hello Neighbour,
I want to try your suggested command of flipping between decks, but everytime I rescan for new devices and clicking ok, my Xponent is not available anymore. Any idea why this is happening?
DJ Jodi
DJ Homeboy wrote :
For those of you with an RMX, Steel, VMS4 or any other 2 deck controller that would like to control 4 decks in VirtualDJ you will need to add some mapping to do so.
Now keep in mind that you can only control 2 decks at a time but using the code I will put below you can assign a button on your controller to swap from Deck 1 to 3 and from Deck 2 to 4.
I have used the button pitch bend + and - on the VMS4. But you can use any button you like.
Used for Deck 1 and 3
Used for Deck 2 and 4
device_side 'left' ? deck 1 leftdeck & deck 1 select : deck 2 rightdeck & deck 2 select
device_side 'left' ? deck 3 leftdeck & deck 3 select : deck 4 rightdeck & deck 4 select
Hello Neighbour,
DJ Jodi
why is this not submitted to the site?? i had to dig to find this. alot easier to just install a custom mapper for the masses that will be asking...thanks
Posted Wed 27 Oct 10 @ 6:32 am
I use the following mappings to use left and right shiftbend to assign decks. The leds are ON for the leftdeck and rightdeck and BLINK when it is active:
Works fine, but I'm having a really weird issue. For deck 1 (left) and 2 (right) everything works fine, yet on deck 3(left) and 4(right) the jog wheel always behaves like it is in scratch mode. I have JOG mapped simply to "jogwheel", and use VDJ 7.0 pro Mac and a Hercules DJC MK4.
PITCHBEND- device_side 'left' ? deck 1 leftdeck & deck 1 select : deck 2 rightdeck & deck 2 select
PITCHBEND- device_side 'left' ? deck 3 leftdeck & deck 3 select : deck 4 rightdeck & deck 4 select
LED_PITCHBEND- device_side 'left' ? deck 1 leftdeck ? deck 1 pfl ? blink : on : off : deck 2 rightdeck ? deck 2 pfl ? blink : on : off
LED_PITCHBEND+ device_side 'left' ? deck 3 leftdeck ? deck 3 pfl ? blink : on : off : deck 4 rightdeck ? deck 4 pfl ? blink : on : off
Posted Sat 30 Oct 10 @ 8:57 am
Hi, I had this issue too, i think it's a little bug or just something that doesn't behave like you'd think. It seems that the "vinyl mode" or "CD mode" in the settings page of vdj only gets applied to decks one and 2 or something like that.
What I did was just set a keyboard shortcut to "vinyl_mode 0", you'll only need to use it once then you can delete it. It only gets applied to the active deck so use the tab key to make each deck active then press the key to turn vinyl mode off.
Posted Sun 31 Oct 10 @ 2:54 pm
There is an example on the page http://www.virtualdj.com/wiki/VDJScript%20Examples.html for mapping a single button to turn vinyl (Scratch) mode on/off for all 4 (Or 6) decks.
Posted Sun 31 Oct 10 @ 4:34 pm
@ reigar = check your comand input again ,you probably just missed a space between the letters for deck 3,an honest mistake....hope that helps..and yes..theres a bug with deck 3 & 4 switchin to cd mode from Vinyl (scratch) mode.though using the command "vinyl_mode 0" (and "vinyl_mode 1" to get scratch back on..) helps...they shoul fix this in the next version we hope...
Posted Sun 07 Nov 10 @ 7:27 pm
Would like to amend the browser mappings on the VMS4. I rarely load direct from the browser to a deck, but tend to go from browser to playlist to deck...
Currently the effect and sampler knobs are assigned to folders and files, and press to select/load.
I'm thinking that one knob could be used inconjunction with browser_window to allow complete access to the browser but pressing would load a file direct to deck.
The other knob to browse the content of the current window as selected by the above. Pressing this one would load the track to the playlist, but if you are in the playlist then it it would load it to the deck.
All seems possible, but have yet to venture in to nested/complicated scripts so some pointers would be appreciated.
Cheers,
Roy
Cheers,
Roy
Posted Tue 09 Nov 10 @ 6:17 pm
JpBoggis...your the Savior!..that was the code i wanted allright.Proper scratch button & pfl ,running smooth...thanks...did'nt have time to try till last nite....set my left & right buttons BACK to Browser mode (needed that) and I recomend this to everyone !! yeap!
Posted Tue 09 Nov 10 @ 8:35 pm
Could someone tell me how I can cycle between skin panels?
For example, make one button cycle between Player/Loops/Effects panels on Deck 1.
Posted Tue 07 Dec 10 @ 8:07 am
Actions (mapping) to cycle through the panels Player-Loop-Effects at the VirtualDJ 4Decks Skin
This action toggles between those panels for the selected deck
This one is for controlers, you assign to a button that has left and right side
one button to toggle deck 1 and deck 2
and one button to toggle panels on deck 3 and 4
deck 1 select ? skin_panel 'deck1a' on ? skin_panel 'deck1b' on : skin_panel 'deck1b' on ? skin_panel 'deck1c' on : skin_panel 'deck1a' on : deck 2 select ? skin_panel 'deck2a' on ? skin_panel 'deck2b' on : skin_panel 'deck2b' on ? skin_panel 'deck2c' on : skin_panel 'deck2a' on : deck 3 select ? skin_panel 'deck3a' on ? skin_panel 'deck3b' on : skin_panel 'deck3b' on ? skin_panel 'deck3c' on : skin_panel 'deck3a' on : deck 4 select ? skin_panel 'deck4a' on ? skin_panel 'deck4b' on : skin_panel 'deck4b' on ? skin_panel 'deck4c' on : skin_panel 'deck4a' on
device_side left ? skin_panel 'deck1a' on ? skin_panel 'deck1b' on : skin_panel 'deck1b' on ? skin_panel 'deck1c' on : skin_panel 'deck1a' on : skin_panel 'deck2a' on ? skin_panel 'deck2b' on : skin_panel 'deck2b' on ? skin_panel 'deck2c' on : skin_panel 'deck2a' on
decice_side left ? skin_panel 'deck3a' on ? skin_panel 'deck3b' on : skin_panel 'deck3b' on ? skin_panel 'deck3c' on : skin_panel 'deck3a' on : skin_panel 'deck4a' on ? skin_panel 'deck4b' on : skin_panel 'deck4b' on ? skin_panel 'deck4c' on : skin_panel 'deck4a' on
Posted Tue 07 Dec 10 @ 11:06 am
Ok I don't own one but would any of these codes work with the Numark Mixdeck?? I know the code to swap timecode control but you can trigger effects and such so I guess in theroy one of these codes would work, right??
Thanks for the time
Huey
Thanks for the time
Huey
Posted Tue 28 Dec 10 @ 7:50 am
Yes, they work for all the controllers
Posted Tue 28 Dec 10 @ 8:31 pm
djscottym wrote :
thought i'd add this for anyone wanting to map 4 decks to 2 cdj400's. i have it mapped to the eject button so that the left cdj swaps between decks 1&3 and the right cdj decks 2&4:
action_deck 2 ? deck 4 assign_controller 1 & deck 4 rightdeck : action_deck 4 ? deck 2 assign_controller 1 & deck 2 rightdeck : action_deck 1 ? deck 3 assign_controller 2 & deck 3 leftdeck : action_deck 3 ? deck 1 assign_controller 2 & deck 1 leftdeck
Thank you so much for this script!!!! works like a charm!!!
However I had uncheck "show midi devices" from the mapper options before it worked.
Posted Sun 02 Jan 11 @ 1:19 pm
Ok thanks bro!! Now I have 1 more question. Does the swap button have to be mapped to the controller or can I have a button on my keyboard. Hmmm...........let me try again, ok the button that I use to swap decks, does it have to be on the controller itself or can I use a button on my keyboard?? That way I wouldn't have to give up a button on the controller.......
Hope that makes sense, lol!
Huey
Posted Mon 03 Jan 11 @ 2:53 pm
For keyboard, you cant use device_side, so it has to be a liitle different.
To swap betwwen the lefts and the rights decks, you will need 2 buttons.
button for the left deck swap
button for the right deck swap
Posted Mon 03 Jan 11 @ 9:11 pm
I had a APC-20... I think I had enough boutons and sliders to remap the whole control for new 4 decks on the new Virtual dj pro 7.... problem, is I want to specific each deck with their own comands
problem is I had to clcik that manual, ir order to had each deck his own comands..... also i dont had a clue if i wrote this coman right..... ![](/image/94403/51121/Snapshot 2011-01-04 14-13-17.tiff)
as I said want to used 4 decks with a APC-20... and a Hercules RMx.....
Posted Tue 04 Jan 11 @ 4:20 pm
PabloivanRv wrote :
I had a APC-20... I think I had enough boutons and sliders to remap the whole control for new 4 decks on the new Virtual dj pro 7.... problem, is I want to specific each deck with their own comands problem is I had to clcik that manual, ir order to had each deck his own comands..... also i dont had a clue if i wrote this coman right..... ![](/image/94403/51121/Snapshot 2011-01-04 14-13-17.tiff)
Posted Tue 04 Jan 11 @ 4:26 pm
Did you post any photos ? they are not viewable.
What script ?
If you need to specify actions for decks, then simply add deck x before your commands.
deck 1 play
deck 2 hot_cue 1
etc
What script ?
deck 1 play
deck 2 hot_cue 1
etc
Posted Tue 04 Jan 11 @ 4:28 pm
