| Author |
- Topic: [NEW VERSION] VirtualDJ Pro v5.1 - |
Posted Sun 01 Jun 08 @ 2:11 am
Hello,
We just released a new version: VirtualDJ Pro v5.1 for PC.
Mac version will be following very quickly next week.
CUE is still under discussion at this moment.
On the menu today:
FAME engine:
- new BPM engine with more than 99.9% of correct detections
- new automatic Key detection
- optional automatic Key-Match
- new auto-gain engine
Video:
- video session recording
- fade to black on level sliders
Automix:
- display both playing and coming waveform in songpos graphic
- can move mixpoints on the fly during automix
Timecode:
- new engine "VDJ Timecode v5" for VirtualDJ vinyls, optimized for scratch (the old engine "VDJ Timecode v4" optimized for needledrop is still available)
- new engine "Noisemap" compatible with most noisemap-based records
- new engine "PCDJ" compatible with most miss pinky-based timecode records
External devices:
- Pioneer CDJ-400
- Vestax VCI-100
- Denon HC4500
- Xponent (fixed)
- DJConsole RMX (improved)
New functions:
- smart beat-tap (automatically snap tapped beat to the nearest likely bpm)
- smart play (play directly on beat)
- smart cue (hotcue always in the tempo)
Skin:
- new skin "HE5" featuring all the new functions of v5.1
Small Improvements:
- sharper coverflow
- improved vumeters
Bug fixes:
- many small bugs from v5.0.x fixed...
Posted Sun 01 Jun 08 @ 2:19 am
I'm hitting the DL section straight away
http://www.virtualdj.com/update.html |
Posted Sun 01 Jun 08 @ 2:29 am
excellent. I am, as well. |
Posted Sun 01 Jun 08 @ 2:46 am
sounds great..cant wait to try it
Thanks |
Posted Sun 01 Jun 08 @ 2:50 am
Hi all. Just purchased the new version, so I'm all good to go.
But one thing, is it just me, or does left clicking on folders not seem to work very well?
Thanks
Jon
EDIT: Whoops, you hae to click on the actual icon of the folder, not the folder name. Bit of an annoyance. |
Posted Sun 01 Jun 08 @ 3:17 am
Whoops number two!!!
Had to restart and all is good.
Geez I really should check these things before posting.
My bad
Posted Sun 01 Jun 08 @ 3:54 am
i can't get vdj to read my timecode vinyl. it stays at 0% with the new engine(v5), with the old engine i get 70% and my video pauses a lot. im using a macbook pro 2.4 under windows. im also using the vv soundcard with vv vinyl. |
Posted Sun 01 Jun 08 @ 4:22 am
now its not reading my sound card, it gives me a asio error |
Posted Sun 01 Jun 08 @ 4:27 am
It looks like the Mac version is not available at this moment in time (Mac version will be following very quickly next week.) hopefully then they will have sorted your problems |
Posted Sun 01 Jun 08 @ 4:34 am
im using a macbook pro running windows.
when running my vv box while its pluged it is not detected at all |
Posted Sun 01 Jun 08 @ 4:57 am
Looks like you be making an awful lot of people happy with this update, bpm detection, automix feature and recording video, just to mention a few and not forgetting me with improvements to the RMX, thanks to all the team
now i'm just going to sit back and wait to see how long before someone says when is version....... think i run a book, place your bets here. lol
Just for your information, the user-guide was updated for 5.1 in the install file so do not hesitate to read it. |
Posted Sun 01 Jun 08 @ 5:08 am
djcel don't play me for being stupid and not reading the manual, thats the first thing i do before i post on the forum. yes the manual has three trouble shooting errors and none can solve my problems. also im using m44 needles if that makes a different. and if that was ot directed to me then sorry and ignore my post :) |
Posted Sun 01 Jun 08 @ 5:10 am
sclavel wrote :
FAME engine:
Just going to Analyze a few tracks that I've just downloaded this morning. I see we don't have the 2 BPM options House/Techno or other music anymore. Do we just use scan for BPM for all music types.
Love the new Key Detention though :)
Posted Sun 01 Jun 08 @ 5:36 am
Regarding the new BPM engine, there is a setting in options called "AllowBPM<80", SMART is selected by default. In this mode the engine will calculate the BPM the best it can using WIDE parameters, this is usually correct , but with a minority of songs it can lead to half values. If you are scanning files with a higher BPM than 80, you can turn "AllowBPM<80" OFF, which like its name implies will only look for higher BPM values. |
Posted Sun 01 Jun 08 @ 5:39 am
Come again Bagpuss, that went over my head a tad.
*Edit* Get it now, my option is disabled, is that by default. Got my thick head on today. Also love the new View in the timecode config, weird or what,lol
Posted Sun 01 Jun 08 @ 5:43 am
think what he means jim if you know what your going to be analysing say like dance, house etc and not a slow rnb track do what bagpuss says, think thats what he meant... lol
Posted Sun 01 Jun 08 @ 5:48 am
Something to know too:
headphone_mix() function was changed (read the comment in the keyboard shortcut list)
New VDJ functions:
"beat_tap",
"key",
"key_smooth",
"smart_play",
"smart_cue",
"effect_slot_scroll",
"scratch_wheel",
"scratchweel_touch",
"vinyl_mode"
New skin textitem:
- %bpmex: bpm with 2 digits after dot
- %bpmexx: bpm with 3 digits after dot
- %key: original key of song
- %Pkey: key of song including key modifier
- %camelot: camelot key of song
If you want to change with the pitch, add P in front like for every other text item: %Pbpmex or %Pbpmexx.
You can now use chan="automix". It works with "title", "author", "comment", "bpm", "key", "level", "time", "start", "end", "firstbeat", "lastbeat", "linkedvideo". |
Posted Sun 01 Jun 08 @ 6:52 am
sclavel wrote :
FAME engine:
LOL: second song i analyse is wrong. Not even x2 or /2. It says 84.7 on a song of 128.
Also: no more Mixed In Key numbers? I just see D#m, last version added a number to mix easier.
EDIT: like... the 15th song says 131.4 but the bpm is 130.
Posted Sun 01 Jun 08 @ 6:59 am
I've just installed newer version of VDJ.
In first sight I noticed that wave of single track is smaller than in older version.
Why did you change that?? |
