is there acheaper version of virutal dj
Posted Fri 01 Feb 08 @ 7:34 pm
[scatter]
LMAO! LOL! ......You have to spend money to make money....the VDJ software is good....if it was for $250 i wouldn't mind buying it!!!!! Cause it be worth it....a cheaper version LOL!!!!
Posted Fri 01 Feb 08 @ 9:54 pm
When software for the HC4500 is working 100 %. I think it would be the controller of the year. Ive seen lots of people selling their Denon HD2500s. They all want to buy the HC4500 instead.
Posted Sat 02 Feb 08 @ 12:29 am
Yes u can get the home edition or buy the herc mk2/mp3 n get djc edition. Alternatively u can get Cue LE which came as a gift too when u buy total control etc.
But with the cheaper version, u will have limitation so my advised is full pro is the way to go;) (VDJ Pro, CUE, NVV)
Hope to see u with us soon.
Posted Sat 02 Feb 08 @ 6:24 am
dj-in-norway wrote :
The Denon fix should be out this weekend, according to "roumors":)
Maybe Denon can confirm in this thread, or give more info.
No update yet
No news on Denon DJ Forums or main site
Thread locked on Denon Dj Forum
No comment from Denon
Maybe tomorrow
Posted Sat 02 Feb 08 @ 9:50 am
To:
Dj-in-Norway
I wonder if it’s possible to program bottoms light (get the light on bottoms) in midi mapping
For Denon HC4500
Thanks
Dj-in-Norway
For Denon HC4500
Thanks
Posted Sat 02 Feb 08 @ 10:20 am
yes, its both possible for a user to make his own (a DLL file, you need to know a bit of C++ programming)
http://www.virtualdj.com/developers/
But it will also be so inside VDJ nativly, with support for lights and all
Posted Sat 02 Feb 08 @ 10:22 am
To:
dj-in-Norway
Ok, when I made it should I dropp it in plugins folder ?
Thanks
dj-in-Norway
Thanks
Posted Sat 02 Feb 08 @ 6:44 pm
to.
dj-in-norway
I was thing of "general midi" if a can map light there ?
I leave C++ to Atomix .
Thanks
dj-in-norway
Thanks
Posted Sun 03 Feb 08 @ 9:33 am
No, it's not currently possible to light LED's via the general MIDI mapper, although this may be possible in a future update to VDJ.
The only way to do this at present is via a mapper plugin .DLL, which requires native support in VDJ, and programming skills (C++) to code the plugin.
I am currently working on a plugin for the controller, but unfortunately the freezing problem still occurs. This will hopefully be fixed when Denon release their updated firmware.
Posted Sun 03 Feb 08 @ 1:56 pm
TO:
jpboggis
How do you do it ?
Does it take long time to do it?
thanks
jpboggis
How do you do it ?
thanks
Posted Mon 04 Feb 08 @ 8:42 am
In case you missed the other thread, new firmware is now up for full native VDJ support!
http://denondjforums.com/viewtopic.php?f=31&t=8735&sid=e3052b1d0159b505e46ac410685dcf19
Posted Mon 04 Feb 08 @ 9:31 am
Ok !!!
halleluja !!
Will it work with PCDJ VJ rev 6 or
do I have to wait for a new rev ?
Thank you very much.
halleluja !!
Posted Mon 04 Feb 08 @ 10:25 am
How do you do it ?
With programming knowledge, a C++ compiler such as Microsoft Visual C++ Express and the VDJ developer SDK ( http://www.virtualdj.com/developers/ )
Also, the full version of VDJ is required (Or Cue or PCDJ VJ) - Controller plugins cannot be used with the trial or home editions.
Depends on your programming skills and what you want to achieve. The more complex the mapper is, the longer it takes to develop, test and debug.
Posted Mon 04 Feb 08 @ 1:19 pm
Ok !!!
halleluja !!
halleluja !!
Works right now, today!
Posted Mon 04 Feb 08 @ 2:21 pm
Will the bew firmware work with the 5500?
Posted Mon 04 Feb 08 @ 2:32 pm
Of Course...NOT!!!!
Each piece of hardware have their own firmware.
Posted Tue 05 Feb 08 @ 3:54 pm
Ok!
I have downloaded Denon HC4500 driver update (1005)
and I use PCDJ VJ rev6.
And guess what, I hade a gig for 240 min and no "hanging"
I notice some small "drifting" when I used the pitch bend.
(Sometimes not always) and It’s the only negative thing
I found.
But the rest it’s fantastic.
My intention with this topic was to make the producer
Hurry up.
I think that we had waited for a long time.
Well I am happy with the result, I thing that some people
At Denon have worked hard to get this update out fast(er).
Thanks for that!!
And Tanyla I will follow your advice now.
I have Downloaded Virtual Vinyl (Cue) rev 7 and they still don’t
Have Denon HC4500 as a native player. (Sad)
I found.
Hurry up.
Thanks for that!!
Posted Tue 05 Feb 08 @ 9:24 pm
Due to marketing issue, Numark software did not have native support, only VDJ have. And pls register ur VV in ur profile. Thanks.
Posted Wed 06 Feb 08 @ 3:05 am
Will my reg number for ex cue or PCDJ VJ do to reg on Atomix forum ?
Thanks
Thanks
Posted Wed 06 Feb 08 @ 6:14 am
