Forum: General Discussion - Topic: Vista sound poping and distortion fix for better sound
Anything about Virtual DJ, Numark Cue, Numark Virtual Vinyl, AtomixMP3, etc... or not about them*
This a general discussion. Please be polite and speak with respect.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
"No license user" can't write personal Email, Msn, Skype, MySpace, Phone number and any other personal contact details in the forum.
VirtualDJ forums
General Discussion
Vista sound...
Author - Topic: Vista sound poping and distortion fix for better sound -
Caliente123
Professional edition user
Posted Tue 31 Jul 07 @ 9:22 am
Vista has audio enhancements thats the play back sound distorted and makes the music pop. To fix this read below
Go to control panel -> Sound -> Properties and disable all enhancemants as explained above.
Also uncheck the two boxes in the advanced tab that say "Allow application to take exclusive control of this device" and "Give exclusive mode applications priority"
Finally and I think most importantly, set the default format option to CD quality 44100 Hz mode.
Reboot and see. It worked for me, hope it does for you too.
Caliente is Great....... Caliente is the best......
dj-in-norway
Atomix Productions
Posted Tue 31 Jul 07 @ 6:17 pm
Good working tips ;)
guarioblackman
Limited edition user
Posted Tue 31 Jul 07 @ 7:57 pm
what
happycat
Posted Wed 27 Aug 08 @ 8:31 pm
You don't know how much good you did me just telling me that. I had thought there was something wrong with my microphone input because it would record a garbled mess and it wasn't like that when i had first gotten it. I thought at first it was something to do with updates because i'd read that vista updates could negatively effect your audio but after i reinstalled and it still did the same thing after a fresh install i knew that wasn't it. it downloaded updates against my wishes since then and then after changing the settings you said here it started working like new again. I am so glad. i had thought i was going to have to get and external usb sound card and my extigy i know already didn't work so i figure it wouldv'e been money down the drain. thanks
tayla
VIP Member
VDJ radio fan
Posted Thu 28 Aug 08 @ 4:36 am
thanks, will have a look at that... "Caliente is Great....... Caliente is the best......" you shouldn't keep putting yourself down as much mate,lol.
rixrecords
Posted Sun 31 Aug 08 @ 7:36 am
Still having problems any other suggestions
Andrew87
Experienced pro user
Posted Sun 31 Aug 08 @ 12:18 pm
Surely you don't want to do that, having dedicated control of a device is a good thing! Those settings would only affect WDM mode anyway not ASIO. I think WDM always resamples to 48 khz too, although maybe this was only in XP.
Steven725
Posted Fri 07 Nov 08 @ 4:55 pm
Didn't seem to help for me... But turning the wireless off did wonders
Site map
(C)opyright Atomix Productions 2008
Software
VirtualDJ Pro
VirtualVinyl
Numark CUE
AtomixMP3
VDJ HomeEdition
DJC Edition
eJay DJMixStation
DJ-Box
Features
Screenshots
Trial Version
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Sound Effects
Video Effects
Samples
Languages
Grafx
Tools & Drivers
Forums
Users Network
Wiki
Radio
Atomix Productions
VIP DJs
Disclaimer
Ask a question
View your tickets
Wiki
