Topic: I need help with sound to you pros out there...
... First off, is there a setting that makes all the sound levels even like a compressor or something? I was DJ ing last night and some songs came in quietly and some were way too loud... Also, is there a way, now that I can play music videos with AC3 audio, that the sound quality could be improved... The sound from those videos are very faint and tinny... Please and thank you in advance for any help... DJ Eddie
Posted Mon 11 Sep 06 @ 2:28 am
there is a setting in vdj ;but u would hve to let the somg load completely b4 bringing it in to mix it (so it can read /analize volume). a faster way of doing this would be using mp3 gain ;
this is a free program and even worth payin for ...
http://mp3gain.sourceforge.net/download.php
this way you can still mix songs as soon as u load them cause they will b already @ the same level (no need to analize em ).where are u getting ur vids from ? maybe use a video editing program to bring up the volume( sound forge does this also; thers a free demo version but dont know if it's limited or not)
hope this helps
for videos ..try this demo out......
http://www.mainconcept.com/site/index.php?id=813
The Encoder offers a simple as well as a professional interface. The latter enables experts to perfect both their video and audio streams by adjusting a great number of settings and parameters, including the bitrate, in order to obtain high-quality results for professional production environments.
Posted Mon 11 Sep 06 @ 2:43 am
Be very careful with the Auto-Gain though depending on what type of music you are playing. Seems to have a little trouble with tracks that have some sub-bass. I've had some hip-hop tracks bottom out from the gain being set too high when the bass kicks in.
Posted Mon 11 Sep 06 @ 2:58 am
yea ..i usually keep it @ the default 89.0 ;as long as everythings the same level, u can always turn up amp or mixer main volume if it's not loud enough ;-)
hers is where you can try out soundforge demo also :http://www.sonymediasoftware.com/download/step2.asp?DID=559
but like dj derricke said
Quote :
Be very careful with the Gain though depending on what type of music you are playing.
Posted Mon 11 Sep 06 @ 3:04 am
cstollPRO InfinityMember since 2004
stellarerazm wrote :
... some songs came in quietly and some were way too loud...
What is your Auto Gain set to in the config?
cstoll
Posted Mon 11 Sep 06 @ 4:04 am
My autogain was disabled...What should it be at???
Posted Mon 11 Sep 06 @ 4:26 am
DJ-ALFPRO InfinityModeratorMember since 2005
Put it at "Always 0dB".
Posted Mon 11 Sep 06 @ 7:15 am
bogartPRO InfinityMember since 2004
Agree with DJ-ALF, always "0" db with ver 4.
Also be sure is tracks are not already analyzed that you let them completely load first.
Posted Tue 12 Sep 06 @ 1:16 am
Hi,
autogain does the trick most of the time, but if you want a compressor, you can download a VST compressor and use it in VDJ :)
Here's a simple one
http://www.digitalfishphones.com/main.php?item=2&subItem=5
The other 2 tools in the pack probably arn't that useful for VDJ, but just download the zip file and copy .dll file to Virtual DJ/Plugins/Sound Effects folder if you fancy giving them a go.
Or there's more complicated ones here:
http://www.digitalfishphones.com/main.php?item=2&subItem=3
http://www.digitalfishphones.com/main.php?item=2&subItem=4
Posted Tue 12 Sep 06 @ 1:01 pm
