Unfortunately I don't own any iOS devices so cannot investigate that one myself, however it has been confirmed and reported.
Update: New build is live in the play store.
Posted Sun 07 Jun 15 @ 7:38 am
I have a couple of Android tablets but don't see the point of paying for it all over again. It's the only thing I really use my 1st gen ipad for so would be great to get a fix.
Posted Sun 07 Jun 15 @ 9:20 am
OK cool Scott, got it downloaded but it crashes my Mac every time I try to load a track from the remote.
I think about 4 or 5 crash reports have been sent in.
Posted Sun 07 Jun 15 @ 11:32 am
There is one crash report on the server Huey.
Someone should look into it.
Posted Sun 07 Jun 15 @ 11:53 am
Sounds good Dan just wonder why only is there cause it's crashed and restarted a bunch of times.
I'll say this, my Android tablet seems to connect a lot faster the my iPad for some reason.
Posted Sun 07 Jun 15 @ 12:15 pm
A fix for that crash has just been submitted to the play store so will be available in a few hours.
Huey has already tested it and given it the thumbs up as fixed :)
Posted Sun 07 Jun 15 @ 6:23 pm
Can anyone help me my remote does not look like the one in the picture at the start of this post.
As soon as i connect it changes and i have no search function
Many thanks Hayden
Many thanks Hayden
Posted Sun 07 Jun 15 @ 6:27 pm
What version of VDJ are you using it with?
Posted Sun 07 Jun 15 @ 7:13 pm
Yes the Android side has been flawless the last hour!!
I've basically had my laptop closed and just used the tablet!!
Well done to Scott and the team 🙏 Well worth the wait!
Look mom, lids closed!!
https://instagram.com/p/3puPg8JNpJ/
Posted Sun 07 Jun 15 @ 9:05 pm
hantscare wrote :
Great improvement guys. Only problem is that when I try and change the skin the VDJ programme locks up as soon as you press the change skin button, i.e. does not load the window to find the skin and the program has to be forced to close. This is on a Mac by the way.
The solution is at the bottom of the skin window in VDJ8. There is a "Tick" box in the lower right hand corner to force VDJ8 to look for Older V7 remote skins. It's checked as on by default.
Posted Sun 07 Jun 15 @ 10:07 pm
Nice job Development Team. This is a tremendous achievement. Kudos to you all.
Note:
I Just went thru clicking on every button and Icon on the Remote Phone skin and cannot find a way to control deck volume. If the volume is already at full volume, the Gain could function as an alternative in a pinch but then, for those of us that use the setting: Auto+Remember, this may really mess things up.
Note:
Posted Sun 07 Jun 15 @ 10:27 pm
There right I between the jog wheels/platters. 2 sliders (up/down) one for each deck........
EDIT,
My bad, didn't read or read to quick, lol! Disregard what I said 🙏
EDIT,
Posted Sun 07 Jun 15 @ 10:29 pm
You don't see them on a phone.
Posted Sun 07 Jun 15 @ 10:34 pm
i had stopped using this app since the launch of VDJ8. I'm impressed with you have done to it and the fact that i can use my iPad is a bonus.
Posted Mon 08 Jun 15 @ 3:13 am
Hi im running vdj v7 the skin changes as it connect and it looks like the old remote
Posted Mon 08 Jun 15 @ 3:27 am
Thats because when you connect it to VDJ7 it is effectively the old remote.
Posted Mon 08 Jun 15 @ 4:32 am
You need v8 on your PC/Mac to use the new features.
Posted Mon 08 Jun 15 @ 4:41 am
Oh ok so i cant just get a new skin so i can use the search function? as its the only bit i would like added
Posted Mon 08 Jun 15 @ 6:24 am
Search will not work in version 7 because you need stuff which is only implemented in version 8.
Posted Mon 08 Jun 15 @ 7:08 am
Way to go, I must say, lekker job with V8 loving it.
Posted Mon 08 Jun 15 @ 8:48 am
