first time in about 6 weeks ive had a prob.was using rmx at home when off sick.doing first gig in that time last nite and sound went off 3 times vdj still playing when i tried to up the gains.once or twice vdj stuck.had to close and open vdj and hercules rmx control a couple of times.reset all my sound set up and was fine then.is it the gains buttons or was it sound set up prob.
set up
input none
output
headphones
soundcard asio
asio driver rmx
outputchannels
master channel1\2headphones3\4
i am just wondering did anyone elses vdj crash because of rmx gain buttons.pitch sliders also wont move until you gig them back and forth a couple of times
set up
input none
output
headphones
soundcard asio
asio driver rmx
outputchannels
Posted Sun 08 Feb 09 @ 5:28 am
djstaffy wrote :
input none
output
headphones
soundcard asio
asio driver rmx
outputchannels
input none
output
headphones
soundcard asio
asio driver rmx
outputchannels
I see your using the RMX in Asio mode. What have you got your Asio buffer set at?
Posted Sun 08 Feb 09 @ 5:38 am
never changed it jim its set at 1056 (23ms) take it its in the rmx control panel
Crash ID=7c9c6fd8 (date=809212158, version=5.2.1 Pro, build=521, thread=Main, dump=8aae9e7c, excode=c0000005 (0,b762a78e))
Crash ID=00481f8f (date=810122212, version=5.2.1 Pro, build=521, thread=Main, dump=8b421451, excode=c0000005 (0,1a2c1a3f))
Crash ID=7c9c6fd8 (date=810182345, version=5.2.1 Pro, build=521, thread=Main, dump=8aae9e7c, excode=c0000005 (0,b37366f6))
Crash ID=7ca2fa13 (date=811022035, version=5.2.1 Pro, build=521, thread=Main, dump=66833800, excode=c0000005 (0,7b50f60))
Crash ID=00481f8f (date=811092340, version=5.2.1 Pro, build=521, thread=Main, dump=8b421451, excode=c0000005 (0,11cfc479))
theese are my crasguards.
Posted Sun 08 Feb 09 @ 5:47 am
