Forum: Old versions
Topic: RMX and scratching with the crossfader - Page: 2
yk23 wrote :
Do you mean go in to the midi settings in the control panel and configure it to run as a midi device and not enabling it as remote?
yeah i know its silly
Posted Wed 10 Sep 08 @ 3:03 pm
yk23PRO InfinityMember since 2006
Do you have an XML midi config file for the RMX, or is it easy enough to config?
Posted Wed 10 Sep 08 @ 3:13 pm
jimmy bPRO InfinityMember since 2007
@fullblast22
This is actually a good idea, I wouldn't mind looking at the xml midi config file aswell.
Posted Wed 10 Sep 08 @ 3:24 pm
I was thinking about trying it in "midi mode" before, but I have other issues and projects I'm trying to sort out(non VDJ related). I think you can save the XML info in this post. If you can that would be much appreciated, it would be a time saver for me. I'm at work right now, I would like to try it out later when I get home.
thanks,
DJ Kavika
Posted Wed 10 Sep 08 @ 3:26 pm
I second that.
Posted Wed 10 Sep 08 @ 3:30 pm
Yep the fader works in midi mode. Just only sucessfully assigned the crossfader so far...
Posted Wed 10 Sep 08 @ 5:32 pm
I a working on a XML, I'm trying to figure out how to activate 2 effects, and looking for a perfect jogwheel setting.
Posted Wed 10 Sep 08 @ 6:40 pm
I was messin around, couldnt get the jog wheel to work correctly. Thanks for all the help.
-David
Posted Wed 10 Sep 08 @ 10:10 pm
Looks good, couldn't figure out quicksearch either.
Posted Thu 11 Sep 08 @ 8:51 am
its not just the bleeding of the faders
I noticed that most knobs and button reponse is a little (1ms) off.
Its especially irritating since this makes the cue buttons rather useless
Posted Mon 15 Sep 08 @ 11:39 am
not just that, none onf the buttons lik EQ or pan are centered, guess we'll have to wait for some kind of fix
Posted Mon 29 Sep 08 @ 3:57 am
i guess everybody noticed that the crossfader doesnt open as soon as move it from any corner. I actually had to mark ans fill in one bar on the cross's scale. even if you have a powerful computer the response isnt too accurate..
Posted Mon 29 Sep 08 @ 4:00 am
