Hello VDJ family. I have a pair of cdj 800's and my tascam x9 mixer with my maya 44 usb. I get sound but NO CONTROL. NO TIMECODE SIGNAL FOUND. I can hear the music, can scratch, can stop the music but not go back to the cue point. What could I be doing wrong??? Since the loss of my TT's last year I have been doing it with the laptop only. I want to get back to cuttin n scratchin but I really want it to be right you know?
Please let me know what i'm doing wrong. When I auto config, I get no timecode signal found.
I can load a song on the laptop, hit play on the 800 and it plays. I can even scratch but if I hit cue, it only pauses. play will resume from the point that I stopped the music instead of the cue point. For no reason I can figure out, the track will start to play in reverse. I love this program.
Been using it for years now but this issue is a heartbreaker for me.
Please help.
Please help.
Posted Wed 19 Mar 08 @ 9:43 pm
I know it's been a long time since i've been here but could I please have some support for my issue? I really want to spin with tccd, something I have not done in over a year. I used to spin tcv but my tables were stolen over a year ago. I'm trying to get back to work cuttin and scratchin but I need help with the timecode issue.
Please help a brotha out.
DJ CITY
DJ CITY
Posted Thu 20 Mar 08 @ 11:27 am
When you say you get sound that must mean the signal is getting through to 'play' the record ? yet no control? bizarre ?
Do you have master tempo switched OFF ?
Posted Thu 20 Mar 08 @ 11:37 am
I have master tempo "on". But on or off I still have the same issue.
Posted Thu 20 Mar 08 @ 11:48 am
Pretty sure the problem is that you are having too loud outputs from the CDJ-800 into your soundcard.
Pioneer CDJ 800 has a very loud output, so you need to use the PRO GRADE timecode
You can download it here:
http://www.virtualdj.com/products/timecode/cd.html
that should fix it ;)
Posted Thu 20 Mar 08 @ 11:56 am
Also, CDJs are a VINYL emulation CD player. So you can get great sucsess by setting VINYL in VDJ timecode settings, and CDJs in Vinyl mode.
If you are more of a "cd player dj", choose CD mode in VDJ, and on the CDJs
Posted Thu 20 Mar 08 @ 12:00 pm
Norway...Real good to hear from you. Old friends die hard. I'm sorry I did not put it in this post, I am using the Pro grade sound level timecode. let me expand on my post...
Hello VDJ family. I have a pair of cdj 800's and my tascam x9 mixer with my maya 44 usb. I get sound but NO CONTROL. When I try to auto config, I get the error message "NO TIMECODE SIGNAL FOUND". I have downloaded the high end Pro grade sound level tccd signal from the VDJ downloads on this site. I load the tccd's into my Pioneer DCJ 800's. When I push play I can hear the music, can scratch, can stop the music but not go back to the cue point. What could I be doing wrong??? Since the loss of my TT's last year I have been doing it with the laptop only. I want to get back to cuttin n scratchin but I really want it to be right you know what I mean?
On the timecode config window, the timecode goes the over the whole wave window with square edges on top and bottom. timecode quaility reads 0%. Turning the gains down does nothing.
Please help.
I have program set in cd mode. I want to be able to hit cue and "go back to the cue point"
Please help.
good to see ya back City ;)
Okey, try this :
- Set CDJs in VINYL MODE, and press play on the player
- in VDJ performance tab, choose AUTO for latency
- in VDJ timecode settings, choose VINYL mode and turn ClearSound OFF
- press AUTO CONFIG
That works great for me at least (but I dont have the maya card)
Okey, try this :
- press AUTO CONFIG
Posted Thu 20 Mar 08 @ 12:02 pm
I tried. The VDJ platter spun backwards. I have all cables connected properly.
This is blowing me. I WANT to use tccd but I need to get it to work. Right now it's not working. I am currently on line and on vdj so if someone can help me, I would really be glad to accept that help. I have a gig tomorrow and saturday and would LOVE to use my tables.
Posted Thu 20 Mar 08 @ 2:27 pm
Backwards?
Check invert phase in the advanced timecode settings, or invert stereo. Try both.
one of the settings, should make it go forwards ;)
Posted Thu 20 Mar 08 @ 3:14 pm
Do you get 100% timecode quality by the way?
Posted Thu 20 Mar 08 @ 3:16 pm
