basically the inverter plugin does nothing for me when i activate it on one or both decks
i even set up my keyboard arrows to nudge plus 1 and minus 1 respectively.
does anyone kno if this plugin works in 5.0?
this would really help me and i greatly appreciate it
thanks
regards
k
thanks
regards
k
Posted Sat 12 Jan 08 @ 5:24 pm
Yes, it should work on 5.x like on 4.x!
It simply inverts the sound wave by 180 degrees. You must align the two tracks perfectly in order to try to subtract some waves. You can notice it because you get a flanger/jet effect when aligning the two tracks correctly. The higher is the cut-off frequency of the flanger, the more you're near to the final alignment (if there is one).
Posted Sat 12 Jan 08 @ 7:16 pm
