I got the same problem.
Denon DJ wrote: "By the red SOURCE button found on either deck. Turn parameter knob and select MIDI".
With the source button I can only choose "PC" or "CD", not MIDI.
If i can use the same "MIDI-setup" as the HD player... where can i find that xml-file?
Posted Thu 22 Nov 07 @ 1:45 pm
ianstein wrote :
I've done everything, downloaded and loaded the midi map file, etc. selected, general midi, activated it, tryied with the 4500 option also, Sound is working ok over Denon's ASio, but can't get the controls to work.
Any help ?
Thanks
Any help ?
Thanks
Try this:
Go into the -preset mode and change MIDI Channel to "1" from "All"
Posted Thu 22 Nov 07 @ 2:11 pm
YOu can only select and see MIDI if you have the latest software version > v1200
Posted Thu 22 Nov 07 @ 2:12 pm
Any help ?
Thanks
Any help ?
Thanks
Try this:
Posted Thu 22 Nov 07 @ 2:14 pm
Where can I find the Denon HD2500 skin??
Posted Tue 27 Nov 07 @ 2:26 am
I think Denon team are working on it, now is not ready ;)
Posted Tue 27 Nov 07 @ 8:40 am
Kewl, thanks for the info.
Posted Thu 29 Nov 07 @ 3:00 am
Hey guys,
i have some problems with my denon hd 2500 and virtual dj.
I can hear music over my Denon Asio Driver...
but if i want to activet the midi controll... my denon dissapierd in DENON DJ ASIO Driver Programm and i can't map it
I have the latest firmware and virtual dj 4.2.
The .xml is already mapped in vdj
thanks
mfg
R'Koon
thanks
mfg
R'Koon
Posted Mon 14 Jan 08 @ 12:51 pm
The Denon 2500 is supported from VDJ 5. Please download the latest demo version of VDJ here from the website and install it.
Ewout
Ewout
Posted Mon 14 Jan 08 @ 1:32 pm
