If you load a sample as a jingle you can loop it, sync it and beatlock it, but if you load it as a loop so it says loop under the sampler start button, you there is an extra pull down window where you can sync the sample to different measures.
I have 1000 of loops that I take off loop discs, when I load them into the sampler they keep getting saved as jingles, (uunder the start button on the sampler it says jingle rather then loop) how can I save them as loops?
Posted Fri 05 Jan 07 @ 5:58 pm
just click loop on the samples menu :)
and it will loop for you and save it as a loop i belive
Posted Fri 05 Jan 07 @ 6:36 pm
