Topic: Not Compatible with 4.1
If I use this use Hercules DJC Mapper v4.0 for VirtualDJ v3.4 and v4.0 The I can’t use the VDJ4.2???
I have MK1
Posted Wed 27 Dec 06 @ 3:27 pm
sbangsPRO InfinityMember since 2004
I have MK1
download the latest one for 4.1
there are 2 copies i belive
one for 3.4 and one for 4 +
Posted Wed 27 Dec 06 @ 7:18 pm
I have MK1
This one I was told is for MK2 Not MK1
Hercules DJC Mapper v4.1.1
This is the next one and it works fine with VDJ 4.0
As I my other post, The mapping worked, I rebooted and wouldn’t work after that..
Posted Thu 28 Dec 06 @ 2:19 am
go to the program folder
look in the external devices plugin folder and delte the two .ini files
then run vdj mapp again
should work
Posted Thu 28 Dec 06 @ 1:28 pm
