HI Guys
Can anyone help got version 4 running on my new system but having big probs with cpu usage causing mega video/karaoke problems, had numerous crashes over last 2 weeks, been throught the bugs pages and turned almost everything off not much else left. my only though from here is that the video card is not enough as its 256mb shared anyone any ideas
Intel Pentium 4 3.2Ghz, Socket 775 Processor
ASRock 775-DUAL-VSTA Socket 775 Motherboard (Supports new Core 2 Processors, and is Vista ready making it future compatible)
1Gb DDR RAM!
Nvidia GeForce 6200 LE Graphics Card! (256Mb Shared Memory)
1Gb DDR RAM!
Posted Mon 18 Dec 06 @ 11:27 pm
256Mb Shared Memory
i suspect this is the cause of your problem
shared memory cards are bad news as they supliment memory from ram and lack some multimedia features
do you have hardware excel on?
Posted Tue 19 Dec 06 @ 12:34 am
no have to turn hardware excel off to play video, problems only start once i display vidon secondry monitor, cpu bar is fine till then but once video appears on 2nd screen things really start goin crazy which graphics card would you recomend
Posted Tue 19 Dec 06 @ 8:02 am
Posted Tue 19 Dec 06 @ 4:23 pm
have just purchased a 512 dedicated will update once its installed and tested hopefully all will be ok after that
Posted Tue 19 Dec 06 @ 6:15 pm
good luck mate !
Posted Tue 19 Dec 06 @ 10:31 pm
need it installed the card ati radeon x1650 pro but now cant get secondary monitor to work its there in settings but everytime i place a tick in the enable desktop bow and apply it just wont work unticks the box and no ifo on screen...slowly losing it here
Posted Tue 19 Dec 06 @ 10:43 pm
It is an ATI problem, use the little DVI to SVGA adapter and put your monitor on the DVI side and use the s-video as normal. I know this as I spent time on the phone with ATI awhile back.
Posted Wed 20 Dec 06 @ 4:00 am
you are an absolute star mate thanks for that just tried it and working like a dream now the worst bit putting everything back together in the flightcase
merry chrimbo
steve
merry chrimbo
steve
Posted Wed 20 Dec 06 @ 6:15 pm
Posted Wed 20 Dec 06 @ 7:21 pm
No problem. OH SWEET I am Experienced now!! LOL
Posted Wed 20 Dec 06 @ 11:45 pm
welldone:)
Posted Wed 20 Dec 06 @ 11:47 pm
Maybe this could be a sticky to the ATI users using the X1x00 video cards. Obviously this doesn't affect the cards with the dual DVI and S-Video cards.
Posted Wed 20 Dec 06 @ 11:49 pm
mentioned this to a few friends that build systems for others and none of them have come across this b4 so opened a few folks eyes out there, tell you my system was ready for goin into the big green bin last night until discobrian gave me this solution ...top marks ya clever sod lol
merry chrimbo all ;0)
Posted Thu 21 Dec 06 @ 12:26 am
You deserved it ;) Noone have struggled and learned more about VDJ this fall than you ;) hehe
So gave u a little recognition for that fact:)
Posted Thu 21 Dec 06 @ 12:46 am
Posted Thu 21 Dec 06 @ 12:50 am
