Topic: Help w/ Configuring Shoutcast w/ VDJ for broadcasting
I need help setting my programs up for broadcasting. I've uploaded Winamp and I am currently running a unregistered version of VDJ4. I've also downloaded the Shoutcast server to connect VDJ to Winamp. I thought I had it all set up and ready to go but I'm getting a "encoder error" when I try to lauch a broadcast from VDJ.
Any ideas on what I'm doing wrong and what I can do to fix the problem?
Posted Sat 18 Nov 06 @ 10:50 am
sbangsPRO InfinityMember since 2004
what encoder are you trying to use?
Posted Sat 18 Nov 06 @ 12:27 pm
The only encoder that I'm running is the one that runs from that ShoutCast source in Winamp. I have it set to 25kbps/22.050kHz,mono. Is this set up right? Or should I be running something completely different?
Posted Sat 18 Nov 06 @ 8:52 pm
Posted Sat 18 Nov 06 @ 8:58 pm
skyfxl, please use bbcode to add links. In this case the width of the forum will remain normal. For example, this is the same link.
Ewout
Posted Sun 19 Nov 06 @ 12:07 pm
NoizZPRO InfinityMember since 2006
I read one other thread that addessed this problem, but , there was no definite answer. I am running virtualdj through the Shoutcast DNAS server, but the url that is attached to my station name is
http://virtualdj.com. How/ Is it possible to change this to a new/different URL ?
Posted Sat 10 Feb 07 @ 5:59 am
this may be possible with a registry change i will check and get back to you
Posted Sat 10 Feb 07 @ 1:50 pm
