Topic: 4.1 will not install?
zshaathPRO InfinityMember since 2005
how to intall upgrade ?? keep getting a message "need vdj installed first" which is intalled?
On my other computer I have both v3.4 and v4 and cannot install upgrade either getting message" you need correct version of VDJ for upgrade? how do I apply this exe upgrade file to v4.o?
many Thanks
Posted Thu 09 Nov 06 @ 7:48 pm
PionaraPRO InfinityMember since 2004
Hi zshaath
If you have both versions on your computer you have probably renamed the latest version so that it would allow you to have both versions on the same machine. If you rename the upgrade the same way you renamed the ver 4 .exe, you should be ok.
I had the same issue. Renaming the .exe's seemed to help.
Cheers...and keep spinnin'...(",)
P
Posted Thu 09 Nov 06 @ 8:29 pm
I cannot download any of the offered skins to my ATOMIXMP3 program. I continuosly get a message: File is either invalid or corrupt.
The program works fine with the original skin but, I would like to be able to change it. Any adivice/help would be appreciated.
Posted Fri 10 Nov 06 @ 3:31 am
sbangsPRO InfinityMember since 2004
hi please dont post in multipul places
try a different download program
or use winrar to check for currupt files
www.rarlabs.com
Posted Fri 10 Nov 06 @ 10:16 am
