Topic: Saving & Keeping your EQ settings+ others...HOW TO ???
itz quite annoying to re-tune my EQ settings each time I exit VDJ. Can the present state that a user exited be returned upon executing application???
Posted Wed 20 Sep 06 @ 6:32 pm
anyone ???
Posted Wed 20 Sep 06 @ 10:22 pm
You mean those 3 EQ knobs? answer is no...
You mean the EQ 16band or 32band effect? Answer is yes...
Only plugins save current state (that is, in VDJ 4)
Posted Wed 20 Sep 06 @ 10:36 pm
apopsisdjPRO InfinitySenior staffMember since 2003
For the eq knobs, well you can do this with keyboard shortcuts...
Eq's are not saved on exit but you can easy recall a "preset".
Use the advantage to create batch (more than one commands in one key)
Then you can have something like eq presets...
Use absolute values: 0-4096 is the full range, 2048 is the middle, or relative: +/- values
Here is an example:
<sc key="1" action="high" value="-256" />
<sc key="1" action="medium" value="+256" />
<sc key="1" action="bass" value="+128" />
Pressing key "1" adds some bass and mids and removes some highs
Use the internal mixer skin to see the changes.
Good luck.
Posted Wed 20 Sep 06 @ 10:49 pm
