I have a strange issue....when i try to add my "music" directory which is pretty big...Virtual Dj will start scanning the directory and then all the sudden virtual dj will close...no warning no nothing...just vanishes..please any suggestions on fixing this issue? Incase it matters i'm running it with Hercules MK2.
Thanks
Thanks
Posted Sun 05 Feb 06 @ 4:25 am
How many files do you have at your MUSIC directory?
Do you have many subdirectories, and sub-subdirectories, and so...?
Posted Sun 05 Feb 06 @ 4:36 am
This sounds to me like a hardware issue?
What are your system specs as well???
P
P
Posted Sun 05 Feb 06 @ 3:27 pm
It could be caused by a lack of memory. I had the same problem a time ago. I had a laptop with 256MB memory. I selected a couple of thousand songs and started to analyse these songs. After 45 minites or so vdj closed without a message. After upgrading to 1G I never got this problem again.
How much internal memory has your pc got?
Ewout
Ewout
Posted Sun 05 Feb 06 @ 9:07 pm
Increase the virtual memory too. Personnally i have set 1GB in Windows to be safe
Posted Mon 06 Feb 06 @ 7:02 am
There was also a bug with WMA support before v3.3
Check if you have any WMA files in your music directory, and check what version of VDJ you're running.
Posted Mon 06 Feb 06 @ 4:19 pm
