Topic: How I can register in VDJ's radio??
How I can register in VDJ's radio??? Is it free for users???
Posted Fri 13 Jan 06 @ 12:13 am
PionaraPRO InfinityMember since 2004
Posted Fri 13 Jan 06 @ 12:14 am
Do you want to listen to the Radio? Then do what Pionara said.
If you want to be a Radio DJ? Then no it is not free for all users. You must first of all upgrade to the Pro version, then apply in the Radio Forum to be a member and add your MSN account, then wait for a reply from one of the Radio Teamers, if the answer is yes, then and only then you can be part of it.
MS
Posted Fri 13 Jan 06 @ 12:17 am
bagpussPRO InfinityMember since 2003
It's of course free to listen to and to broadcast on, and it's running at the moment with no problems, we just don't have 24/7 DJ coverage yet.
To broadcast on the radio you need to own the proffesional version of VDJ, have a fast enough connection and pass a simple test.
Posted Fri 13 Jan 06 @ 12:18 am
Sorry guys...cheers...:o)
P
Posted Fri 13 Jan 06 @ 12:29 am
