Forum: Italian Forum
Topic: NUOVA VERSIONE 1.09
zanardPRO InfinityMember since 2003
Bugs fixed
DJCconsole fader range bug corrected
New features
Invert soundcards option
7.1 output option added in soundconfig
XP10 commands mapper
Can drag'n'drop filelinks from windows to vdj
Stop goes to last used cue
Fade length=none option to play songs from start to end
Search filter in all directories
Search database integrated as a directory-tree item
"Recurse" option in folders' rightclick-menu displays all subdirs files
Ogg vorbis compatibility
"NoModifFiles" entry in registry forbids any file modification
Can copy/move/delete multiple files at once
Keep bpm/comment/etc infos when rename file from inside vdj
New skin layout (full version only)
Loop_in bug corrected
Right-click on beatlock does atomix-like beatmatch
"File info" menu on file rightclick shows bitrate and ID3tag infos
"Bring to listview" button in playlist added
Compatible with all AtomixMP3's effect plugins
New actions
"browser_switch"
"browser_updown"
"browser_open"
"edit_cuename"
"empty_buffer"
Fabio.
Posted Sun 04 Apr 04 @ 10:11 am
neanche 500kb per tutte ste cose??
scusate l'ignoranza ma in poche parole che cosa e' cambiato sostanzialmente???
Posted Tue 06 Apr 04 @ 7:30 am
