Topic: Poll: Screen Resolution? - Page: 2
1024*768 for me
Posted Wed 28 Apr 04 @ 4:19 pm
1024x768 for me
Posted Wed 28 Apr 04 @ 11:33 pm
Hi
I use 1024 on my laptop
I use 1280 on my Home comp
Thomas M
Posted Thu 29 Apr 04 @ 8:05 am
claxPRO InfinityMember since 2004
1024*768 (17" screen CRT)
Posted Fri 30 Apr 04 @ 3:22 pm
crazy88PRO InfinityMember since 2005
1280 x "768" (14" Widescreen... thus 768 on the height)
Posted Fri 08 Apr 05 @ 8:51 pm
Most of us use 17" monitors with max. 1280x1024, but when you turn 1280x1024 in most cases it works in 60hz, which blows your head off, so best solution for my 15" belinea is 1152x864 @ 75hz max. 1024x768 is small, but it works in 85hz.
Well, if you have monitor which works in 1280x1024 @ 75hz or 85hz then there is no problem, but for me, I would like to see option in VDJ default skin in resolutions:
800x600
1024x768
1152x864
1280x1024
1600x1200
and other wide-screen resolutions, BUT NOT in way they made 800x600 skin. That skin is just streched & it SUCKS, you can't see numbers and letters properly. Or you can do trick like in traktor 2.61. It feets all, but when I say all i mean ALL resolutions with only one button :)
I know this is not easy job to do, but look this way: you have made one of greatest DJ softwares on Earth, and you can not make skins with other resolutions :) hehehe... I wouldn't say so :)
Best regards to atomix production, YOU ARE THE BEST, KEEP UP THE GOOD WORK
Posted Fri 08 Apr 05 @ 10:11 pm
djbambiPRO InfinityMember since 2003
1920x1200 17-inch LCD
gotta love those Dell Inspiron 9200, I can run the mixstation skin side-by-side with Acid and/or FruityLoops :)
elof> which skin do you use? for me, the mixstation is fine, even in full screen (although then the wheels are more oval than round)
Posted Fri 08 Apr 05 @ 11:17 pm
1280x1024
Posted Sat 09 Apr 05 @ 1:04 am
DJ RickPRO InfinityMember since 2003
1280x800.
Posted Sat 09 Apr 05 @ 1:38 am
mUd-VPRO InfinityMember since 2003
usualy it is 800*600
with VDJ 1024*768
my next PC , 1280*1024
Posted Sat 09 Apr 05 @ 1:53 am
1024 x 768 work great fo me
Posted Sat 09 Apr 05 @ 1:54 am
1280*800
Posted Sat 09 Apr 05 @ 3:36 am
1024 x 768
Posted Sat 09 Apr 05 @ 6:22 am
1024*768
Posted Sat 09 Apr 05 @ 10:12 am
arjunaPRO InfinityMember since 2004
1024*768
Posted Sat 09 Apr 05 @ 1:19 pm
xeonPRO InfinityModeratorMember since 2004
1024*768
Posted Sat 09 Apr 05 @ 1:23 pm
cstollPRO InfinityMember since 2004
1280*1024 - so I use the 1280*800 skins so I have access to my desktop for using my MP3 Catalog software
Posted Sat 09 Apr 05 @ 3:18 pm
1280x800
Posted Sat 09 Apr 05 @ 3:44 pm
onozHome userMember since 2004
1400x1050 notebook
Posted Thu 24 Nov 05 @ 7:40 pm
1280x800
Posted Thu 24 Nov 05 @ 8:43 pm
73%
