Hi i got a pretty good laptop with 1.6 ghz , 512 ram and a radeon mobility
Sometimes makes my atomix to slow down and repeat the sound!
Have u already experienced that?
Do u know how to solve the problem?
Many thanks :)
Tom
Many thanks :)
Tom
Posted Fri 17 Jan 03 @ 4:13 pm
Hee there! Have you tried installing the latest version of directx and soundcard drivers? This may help! If you trie to play mp3's from a network or cd-rom you had better put them on your own harddrive, since that is the fastest way to play them.
Greets,
Roderick
Greets,
Roderick
Posted Sat 18 Jan 03 @ 1:08 pm
1) Make sure you have NO other programs running in the background (virus scanners, MSN, etc)
2) Make sure you have the LATEST soundcard and video drivers installed
3) Use a more simple skin that requires less graphics (JN Classic, etc)
Posted Sun 19 Jan 03 @ 2:47 am
