Topic: jog dial djconsole, jogdial, how to speed it up
i have the hercules djconsole for 2 days now, and i am trying to understand how to mix two records together.
i am used to vinyl so i was trying to play the record, listen to it, then stop en reverse 3 beats , then hold it (on beat 1)
then start it, at the same beat1 of the other record, then mix together..
but i noticed i have to turn the jog dial like mad to reverse it just 3 beats!
how can i speed up this reverse jogdial action?
if not possible, would it be an idea for next version ??
bart
Posted Mon 05 Jan 04 @ 12:49 am
That's one of the major complaints of the unit. i have the same problem. hoping for a fix too. is anyone else hoping for that. would be able to mix easier then and manually. They could even make it scratch then. But would the unit itself need to be reprogrammed? Or can they make a fix?
Posted Mon 05 Jan 04 @ 2:25 am
i think the jog dials do there work fine,
it's the software that needs to be changed, something like;
when you press stop, then increase jog dial speed, when playing, decrease speed
there would be more ideas possible, i think.
maybe the developers team can respond on this ?
bart
Posted Mon 05 Jan 04 @ 2:40 pm
