Forum: VirtualDJ Skins
Topic: help !!!! I have problems downloading the skins
because when i make a skin download it comes as html file
and it should be ( i think ) a xtml file
Posted Sun 08 Sep 02 @ 10:13 pm
HomeboyPRO InfinitySupport ManagerMember since 2003
Should be an xml and bmp file. Try right clicking on the icon of the skin and save target as... on your desktop. Extract files to the root folder of atomix under skins.
.:DJ Homeboy:.
Posted Mon 09 Sep 02 @ 4:18 am
como descargo un skin
Posted Fri 13 Sep 02 @ 2:48 am
DJ RickPRO InfinityMember since 2003
Actually, it should be a zip file which contains an XML file, and a BMP file. These 2 files need to be extracted to your atomix/skins directory.
Posted Fri 13 Sep 02 @ 4:25 pm
