Topic: Crossfader Transition FX ... like Algoriddim Djay Pro 5.x
Does Virtual DJ have an equivalent to Algoriddim Djay Pro's "Crossfader Fusion" ??
Algoriddim's Crossfader Fusion™: Uses an Intelligent algorithm and applies creative effects as you transition between tracks (using the Crossfader). It also performs "TEMPO BLENDING".
TIA.
Posted Mon 28 Oct 24 @ 2:31 pm
To narrow your search in the manual, look for Mix FX and Auto BPM Transition.
  • VirtualDJ had Mix FX (equivalent of Crossfader fusion) for at least a year or more
    It may not have all of the same options though
  • VirtualDJ had auto_bpm_transition (a separated but related function) for about a bit more than a year too.
    Check out @Klaus video demo/description of it.
Thank You GroovinDJ
Thank You ... DJ VinylTouch
This was a brilliant link. This Guy's got tons of videos for me to dive into & chew, especially me being a noob.
Thank you once again :)
P.S. Is there any downloadable PDF File link for the entire VDJ Manual?
Yes if you follow the link, on the top right side there is a small icon of a printer. When you click that, it loads a PDF (which you can then save).
Can this be linked to trigger the auto bpm/stem cuts on fader start?
If the fader sends MIDI for its position that the software can recognize, I would think so.
