Hello to the community.
I discover a small problem with the LED_pitch_zero of the Mixon 8 pro.
The factory mapping is not set correctly and the led not working properly when you set the pitch to zero:
LED_PITCH_ZERO
Factory default: pitch_zero
Custom mapping: param_smaller pitch_slider pitch ? blink : param_smaller pitch pitch_slider ? blink : get_pitch_zero 1%
It's Working like a charm. :)
Also i discover something wrong with the CF Curve knob.
The factory default mapping is wrong too about that:
Your must delete CROSSFADER_CONTOUR key and replace by this one:
Key: CROSSFADER_CURVE
Action: crossfader_curve
Now the CF Curve knob work properly. :)
Maybe i going to discover more minor problems with this controller, if it's the case i update this tread with what i found.
Best regards :)
LED_PITCH_ZERO
Best regards :)
Posted Sun 21 Apr 24 @ 7:43 pm
Led Pitch zero is now mapped as above.
The name of the key in definition is now CROSSFADER_CONTOUR so the original Mapping is working correctly now.
Fixes are available as a silent update (require a 2nd restart of VirtualDJ) in Builds ending at xxxx.2055
Posted Mon 22 Apr 24 @ 11:49 am
