Hello,
We utilize Denon prime Go for our small, remote events.
While in standalone mode, the small jog wheels located on each deck work perfectly. However, with virtual DJ (in computer mode) that same Jog wheel will only work when you depress the shift button. It will then skip ahead several measures. I am looking to custom map the same jog wheel to jump a beat or two ahead without depressing the shift button.
What would be a command that would advance the track only while turning the jog when?
Thank you for your help in advance!
Posted Sat 28 Jan 23 @ 7:23 pm
