left side of the deck tempo / pitch slider and efx knob don't go to 100%
not sure why this would have stopped working all the sudden. checked input data and it's not the hardware. DDJ-SR2
i saw this post and it makes me think there maybe another issue at hand?https://www.virtualdj.com/forums/248565/VirtualDJ_Technical_Support/Pioneer_XDJ_XZ_pitch_fader_not_alligned_to_0_.html?search=%20fader%20100%&page=1.45
Posted Mon 07 Nov 22 @ 4:52 pm
The min/max is dependent on your range setting
Posted Mon 07 Nov 22 @ 5:06 pm
How would i adjust the range setting for the entire left side of the deck nearly?
the photo shows that i cannot take the tempo slide all the way up to pick up the control . the hardware slider is all the way up and should be in the same position as the ui slider. It's not just the tempo slider it is also the efx knobs
Posted Mon 07 Nov 22 @ 5:11 pm
Digging deeper i found that both the efx knob and tempo slider are short on the negative value by 17.
This photo shows the efx knob 3 turned all the way to the right and the tempo all the way up ( slower)
Posted Mon 07 Nov 22 @ 6:19 pm
