hi. i noticed a problem which started a few days ago.
sometimes my fx2 buttons and pad buttons dont work if i press it. it does not even lit up. sometimes when i open VDJ 8 it works and all of a sudden it stops working. strangely it is only on the right deck. (deck 2).
when i use MIDI-OX to check if all my buttons on the controller works it does work. and i have to restart my laptop and then all the buttons will work in VDJ. also if i want to use fx2 i must press the WHEEL button (jog wheel) and then it will select fx2.
thats the version im using. v8. 5-6 b7183.
Posted Sat 29 Oct 22 @ 11:13 am
