Hello, I am using a controller (it is the Roland DJ 808, but I don't think it really matters). Holding the load button for more than a second is supposed to unload a song from a deck, however, that doesn't seem to work. Are there other ways to do this? Perhaps directly in VDJ?
Posted Wed 13 Apr 22 @ 6:51 pm
I could be wrong but doesnt look like its mapped that way
You can try change the LOAD entry in the mapper (search at bottom of the mapper section).
And change the entry to holding 1000ms ? unload : load
Posted Wed 13 Apr 22 @ 8:55 pm
Indeed the default mapping was changed at some point and the LOAD buttons offer Clone when double-clicked. Manual is updated.
If you still need to unload while holding, use the script above.
Posted Wed 13 Apr 22 @ 11:19 pm
Thanks for this clear answer! I will try that later today :)
Posted Thu 14 Apr 22 @ 7:21 am
