Topic: Ddj 1000 display frame rate fix?
listen2PRO InfinityMember since 2005
I'm a using a ddj 1000 srt and the spinners/markers on the displays seem like they aren't as smooth as in serato. It appears only to be visual, but does VDJ have any ability to adjust or smooth out the motion?
Posted Wed 26 Jan 22 @ 1:52 pm
The setting is "controllerRefreshRate" and should be set to 0 for most systems.
0 means "as fast as possible" = 100fps
Posted Thu 27 Jan 22 @ 9:56 am
Thanks, I've checked the setting and it was already at 0.
Posted Sun 30 Jan 22 @ 2:26 pm
