Should mix_now and auto_crossfade cause the next deck to start playing when either of those commands are envoked.
If the answer is "yes they should " then what would cause the next deck to NOT start playing?
My memory tells me that the next deck should start playing, but I don't seem to get it to work.
Thank you for all help and suggestions.
Posted Mon 13 Dec 21 @ 7:07 pm
