klausmogensen wrote :
I don't think I did much
- I enabled playcount in a playlist
- I ordered by it descending - that gives me just the tracks in the playlists by default
- I set the search criteria to "all local files" and disable "search in local folder" like seen in the beginning of the video
That was it - then it searches globally, and keeps ordering by playcount descending when I change playlists
I think the search criteria settings were the important ones for me
I envy you my friend))) apparently the problem is only for me, I made the settings like you, but it did not help me ((( and the support service could not solve the problem(((
Posted Wed 02 Jun 21 @ 9:26 am
Nicotux wrote :
yes this is weird, with same search settings sort order for search is lost between search (reset to none) here too
https://skr.sh/s8MQysbkr1m?a
Posted Wed 02 Jun 21 @ 9:32 am
Posted Wed 02 Jun 21 @ 10:11 am
Sort order stay the same as current folder, not a specific to search result
Sort result DO NOT have own ordering setting and sorting result modify browser file search ordering
but do not keep in consideration keepSearchOrder setting
Difference between two videos: only folder change but no column sort between the two searches in second one
whatever setting keepSearchOrder can be browser "files" sort order is used with search (file=Play Count|file(samp)=Pos|...)
sorting in search result (file=-Title|file(samp)=Pos|
resets next browser file sort order to none (|file(samp)=Pos|...)
(looks to be the bug)
with keepsearch is on result, search result keep browser "files" (file=Play Count|file(samp)=Pos|...)
moving folder keep ordering (file=Play Count|file(samp)=Pos|...)
sorting (file=Title|file(samp)=Pos|...)
change what sort result will show (file=Title|file(samp)=Pos|...)
browser files keep sort order (file=Title|file(samp)=Pos|...)
with keepsearch is off search result reset to none (|file(samp)=Pos|...)
moving folder reset to none (|file(samp)=Pos|...)
Still works fine here - with the settings I have set to the search in the beginning of the video
djmishagra wrote :
open the left column and select any playlist, then try to find the file I mean it
you can send me your ssettings.xml file? I'll try with your settings )
Posted Wed 02 Jun 21 @ 10:12 am
