Hi Virtual DJ,I just use it for few days..Start recording some mix but i found that the recorded mix volume are low.I save it ask mp3 and make it as 320kbps.Gain of each deck are set at middle & master are turn up fully but it still the same.Im using Inpulse 300 from Hercules and use my laptop to connect to the speaker.
Posted Mon 25 Jan 21 @ 4:30 am
The master volume does not react to the recordings.
If it is too quiet then you have to set the Zero DB higher.
Posted Mon 25 Jan 21 @ 10:35 am
