About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Audio dropouts? Denon MCX 8000
I need help with a tweak so I don't get "hiccups" or I guess they are audio dropouts. I can go a couple of shows in a row with the sound being fine then the next time I will get at least 12 dropouts in the night. If it happens once in a night it will do it about 12 more times. I would need someone to explain latency to me if that is what it is.
Denon MCX8000
Latest Build of Virtual
Windows 10 64 bit
etc.
Thanks!
Posted Thu 18 Jul 19 @ 1:35 am
Check for latency caused by drivers on your laptop. HP and Dell machines are particularly bad for this. also increase the latency setting in your MCX8000 Asio driver control panel.
Posted Thu 18 Jul 19 @ 6:50 am
What is a good latency setting past 512?
Posted Thu 18 Jul 19 @ 2:33 pm
Whatever doesn't cause dropouts. Every system is different.
Posted Thu 18 Jul 19 @ 3:32 pm
Thanks!
Posted Fri 19 Jul 19 @ 12:09 pm
