Forum: VirtualDJ Skins
Topic: Where is Master Volume in VDJ 8 Default Skin?
I don't see Master Volume level in VDJ 2018, Default Skin for Mac OS.
Did i miss something?
Is there a setting or button to enable it?
Thanks
Posted Fri 31 Aug 18 @ 10:51 am
AdionPRO InfinityCTOMember since 2006
Posted Fri 31 Aug 18 @ 12:08 pm
Thanks, found it.
But Master Panel does not respond to either Master volume or headphones, Cue/Master control on my controller. Although those controls work in reality - Master Volume, Headphones and other levels react accordingly.
Denon MC6000 on Mac OS High Sierra (MBP Pro 2015)
Here is my Audio Settings page
Posted Sat 01 Sep 18 @ 11:18 am
Posted Sat 01 Sep 18 @ 12:02 pm
groovindj wrote :
Some controls are hardware only - they don't send MIDI, so the knobs on screen won't move. If you have the real thing in front of you, there's no need to have or use those same controls on screen.
Yes, but in VDJ 7 on the same computer Master Volume level knob moves the same virtual knob. Also, on another skin it does show Master Level in numbers from 0-100. That made it easier to adjust Master level. That's why I'm asking.
Wonder if this issue is prevalent with other Midi DJ controllers.
Is there a way to fix it through mapping?
Posted Mon 03 Sep 18 @ 3:39 pm
Read the manual...
Quote :
Some of these elements offer MIDI notes and they can be used for your own mapping needs. These elements are not used in default mapper of VirtualDJ
Posted Mon 03 Sep 18 @ 4:58 pm
We will fix this in a future update, but in the meantime do this..
- Assign MASTER_VOL key as..
master_volume
- Change the ONINIT key from ..
deck 1 filter_activate off & deck 2 filter_activate off & deck 3 filter_activate off & deck 4 filter_activate off & mixermode ? nothing : fake_mixer on & fake_eq on & fake_gain on
to ..
deck all filter_activate off & fake_master on & mixermode ? nothing : fake_mixer on & fake_eq on & fake_gain on
- Change the ONEXIT key from ..
deck 1 filter_activate on & deck 2 filter_activate on & deck 3 filter_activate on & deck 4 filter_activate on & mixermode ? nothing : fake_mixer off & fake_eq off & fake_gain off
to ..
deck all filter_activate on & fake_master off & mixermode ? nothing : fake_mixer off & fake_eq off & fake_gain off
Useful info : Custom Mapping
Posted Tue 04 Sep 18 @ 7:13 am
Done. Thanks!
Now I need the skin, which would show Master Volume level in digits. :)
Posted Fri 07 Sep 18 @ 4:38 pm
