groovindj wrote :
I just noticed another issue, with the BPM displayed on the HC4500.
In VDJ 8 it disappears if you use some of the HC4500 buttons to change the displayed info.
You can get it back by nudging the pitch fader, but in VDJ 7 it doesn't disappear.
groovindj wrote :
@Adion, don't forget to fix the issue with the BPM display of the HC4500. :-)
This issue is still present in build 3889
Posted Thu 07 Sep 17 @ 7:44 pm
Are there any specific button combinations that reproduce the issue ?
Posted Thu 07 Sep 17 @ 10:03 pm
Take your pick. For example, the time button (below the display, on the left). It toggles the various time info but it also makes the BPM disappear.
Posted Fri 08 Sep 17 @ 5:03 pm
Is there a way of just showing the beginning of the title and artist. When your playing and you look down to quickly see what you loaded, it's much harder to work out what the screen says when you have to wait for the beginning to scroll past.
Just showing the first 10 characters is much easier to read if your in a hurry.
Posted Sat 30 Sep 17 @ 7:33 am
Anyone? Waiting for the beginning of the title or artist to scroll past is a pain. It's easier to just read it off the laptop screen at the moment. Bit of a waste having text on your controller.
Posted Tue 17 Oct 17 @ 5:04 pm
