About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: vdj 8 vs rekordbox dj sound difference - Page: 1
All settings on mixer and laptops are same. Both laptops are the same spec
In fact laptop running rekordbox dj the master volume is set at 3 o'clock and the laptop running vdj8 is at max please watch the video and let us know what you think
please click on the link
https://www.youtube.com/watch?v=Wb4Hu-7hFxk&t=18s
Posted Tue 07 Mar 17 @ 9:09 pm
VDJ has come a long way but it still has a flat or dull sound to me. Bass isn't as punchy and the highs scream.
Even with SDJ I can hear the difference. Even when messing with the eq's you can hear a difference between the programs.
VDJ still needs work.
Posted Tue 07 Mar 17 @ 9:35 pm
i agree
Posted Tue 07 Mar 17 @ 9:37 pm
louder isn't always better .....
Posted Tue 07 Mar 17 @ 9:38 pm
this is very true but sound quality matters :)
Posted Tue 07 Mar 17 @ 9:39 pm
In my case vdj 8 is louder comparable to recordbox check in settings output level on both programs ...
even I set them the same values inside of softwares vdj 8 is louder
try to use on the same computer that's what I did
Posted Tue 07 Mar 17 @ 10:06 pm
hi all settings are the same did double check all that several times in fact rekordbox dj master was set at 3 o'clock and vdj8 was set at max dont get me wrong i still love vdj8
Posted Tue 07 Mar 17 @ 10:11 pm
depends how your zerodb is set in VDJ to be fair. I have mine at -6 to avoid software limiting and compressing the sound. So it will technically outputs 6db less than if i run itunes. +10db would be a doubling of the perceived sound volume, so 6db makes a massive difference. Doesn't matter to me, because i run the sound into an analogue mixing desk where the sound is then gained back to 0db (where it should be) before hitting the speakers. IMHO, and i am OCD about sound quality, then the source file, equipment and speakers are way way more important to sound quality than the software. So unless you are outputting wav or flac files to Funktion-one speakers, then upgrade your gear and tracks for better sound quality, the software has little to do with it.
Posted Tue 07 Mar 17 @ 10:12 pm
I run VDJ at -6 as well and there is a definite difference in sound quality. Doesn't matter if I'm using my Mac or PC I can hear the difference.
It's not that it's bad but it doesn't sound as full, crisp or warm as the other programs.
When scratch over a kick that's where I always notice the difference the most.
Posted Tue 07 Mar 17 @ 10:27 pm
to be fair i do play at some big clubs who do have the bees knees kit and i do buy my music from replica sites as i said before i do love VDJ and yes all settings are the same ie in the software and the middi controller im not running VDJ down as it as lots of pros to other software on the market
Is that because other programs are artificially increasing some of the frequencies though to try and trick you into thinking they sound better, whereas VDJ outputs flat, as it should be so we can tweak it? Beats headphones do the same, and many people buy them because they sound so bass'y and full. Whereas i wear AKG so it sounds perfect. I can tweak it myself if i need to? Sound is such a subjective thing. It will sound different on the same equipment in the same room if its 10 degrees colder. Everyone has their opinion, but thats just mine. I doubt anyone could prove they were right
Posted Tue 07 Mar 17 @ 10:33 pm
I When scratch over a kick that's where I always notice the difference the most.
I dont dance and I cant scratch, so i cant comment on that :) but would that not be more to do with the scratch algorithm?
Posted Tue 07 Mar 17 @ 10:42 pm
this could be the beginning of a new topic lol
Posted Tue 07 Mar 17 @ 10:44 pm
Haha, yeah, you start it and ill join in :)
Posted Tue 07 Mar 17 @ 10:46 pm
whoops
....there it is
Posted Tue 07 Mar 17 @ 10:48 pm
Posted Tue 07 Mar 17 @ 10:50 pm
Hahaa!!
Posted Tue 07 Mar 17 @ 10:55 pm
wish i never posted this now
Posted Tue 07 Mar 17 @ 11:00 pm
Why?? It's your opinion and no one can take that away from you.
No one here is bashing VDJ or any other program.
It's not a big deal bro.
Posted Tue 07 Mar 17 @ 11:14 pm
Page : [>] [>>]
23%
