Hi all,
Since updating to Mac OS X Sierra, I've gotten Virtual DJ to work fine. But my Numark Mixtrack Edge is acting strange. It won't, for example, send two stereo outs even when it's set that way in the settings. I am only able to use the master out to the speakers and cue for headphones, not master for deck 1 and cue for deck 2. Also, there is a strange bug where I can have two cue buttons on at the same time. This never happened before. Do I need a new driver for Sierra? Thanks all!
Posted Sat 08 Oct 16 @ 6:38 pm
its not listed as compatible with Sierra should have checked before the upgrade have a look -> https://www.numark.com/product/mixtrack-edge
goto requirements tab
Mac: OSX 10.6.8, 10.7.5, 10.8.5, 10.9.5, or 10.10;
Posted Sat 08 Oct 16 @ 7:37 pm
But on Numark's page, it says it IS supported.
https://www.numark.com/kb/article/2160
Posted Sun 09 Oct 16 @ 7:42 pm
do you have the latest drivers then must be a update?
Posted Sun 09 Oct 16 @ 8:32 pm
You also might need to update your firmware to the latest version.
Posted Wed 02 Nov 16 @ 4:16 pm
