Forum: VirtualDJ Plugins
Topic: Vloop Out doesn't work anymore
ChreecePRO (OEM)Member since 2014
The plugin doesn't work, i can't activate it...
Also as it worked it had some issues and i proposed something some months ago, on the plugin's thread...
Here is what i think:
There is an opportunity to make it better. The plugin after the repeats that is set to follow, stops in a high volume output and not in a complete fade out (0%). So it fades until 50% of the volume i think and that's not quite right, it sounds like the music is suddenly stopped... It would be better if it fades from 100% to 0% in the duration of the repeats...
Edit: The plugin works, i had it's knobs full left... But have a look at the issue above...
Posted Thu 19 Nov 15 @ 5:16 pm
SBDJPRO Infinity Member since 2006
Working fine here.
What do you mean by 'can't activate it' ?
Edit: I missed you sorted it. I'll consider adding the above.
Posted Thu 19 Nov 15 @ 10:14 pm
