I'm using VDJ 7 with my Numark NS7 and whenever I use the SYNC function, it works but gradually goes out of sync within a couple of seconds.
When I tested it without the NS7 it worked perfectly fine.
Please help me
Please help me
Posted Fri 31 Aug 12 @ 11:59 am
I think the sync only works with licensed versions. Kidding. you should license your version tho, you may get more responses. Here's the thing with sync, and please take my sarcasm with a grain of salt as its not meant to be offensive - you have two better instruments on your head called ears, use those to "mix". Practice, Practice, Practice...stop taking the easy way out and learn your trade
Posted Fri 31 Aug 12 @ 12:08 pm
I'm currently learning that for long term but for now I'm relying a bit on the sync function So, Is there anyway to fix the problem..
Posted Fri 31 Aug 12 @ 12:22 pm
Use your jog wheels to "nudge" the track when it drifts. That is what they are for. Take the controller OFF of scratch mode and try it out...Works fine for me...
Posted Fri 31 Aug 12 @ 12:41 pm
Use the pitch bend buttons to keep it in line. Don't depend on the sync button.
Posted Fri 31 Aug 12 @ 12:45 pm
use ur ears not ur eyes
Posted Fri 31 Aug 12 @ 1:30 pm
i think the djs have spoken, use YOUR dj skill to keep it locked. technology is just a PART of djing. don't mean to be negative but in the long run you will be a better dj. practice practice practice....btw i use NS7 as well.
Posted Fri 31 Aug 12 @ 4:59 pm
yes sir...words of wisdom
Funny, my friend is also experiencing the same problem with his NS7 and Serato itch.
Posted Sat 01 Sep 12 @ 1:13 am
Yep, seems to be an NS7 problem rather than VDJ.
Google for "NS7 sync issue" and even just the Serato forum is full of people complaining about sync (and they're using an NS7).
Some of the posts are from 2009!
Posted Sat 01 Sep 12 @ 5:44 am
