Topic: VirtualDj 8 Sneak Peak - Page: 10.5
The problem is the software working out whether the song is 60 or 120 bpm.
I have tried various BPM scanners in different software packages and none of them are accurate. There is no way the algorithm can detect the BPM perfectly .... how does it know if the song is a ballad or a house track?
There is an option for this in VDJ config, may be worth playing about with that to see if you get better results.
Keith
Can't really understand the mapper problem, when you can make your own with VDJ...
No more discussion on the 3900 in this thread please - as already stated it belongs in the other thread. Further posts on that subject in this thread may be removed.
How do u get all the stars !!!?
I only have 3
Vdj 8 will be great im sure anyway!
Im waiting but not patiently
mostly bribes...
Stop talking about Traktor as if were gods gift to the DJ and maybe you'll get a star or two ;0)
the only thing i want from vdj 8 is to sort out the problems with dual video cards, i've still got 3 or 4 videos skipping each nite...NOT GOOD ENOUGH !!
before people get carried away with feature requests, rock solid proformance should be the priority !
With MIX EMERGENCY you can only use a Mac but because of that the software is rock solid,
I think a list of approved laptop spec's including operating system type should be compliled by staff or approved pro's on the forum.
Best solution is to lock your video card down so that VDJ is only executed on the high performance one. This function is provided by your laptop vendor in either BIOS or driver (or sometimes a combination of both) form.
What will this cost to upgrade from 7? Will it be free if you have the pro version already?? Looks like its going to be good.
Updates are always free for VirtualDj PRO Full users.
Actually, if you have virtual dj PRO, the updates are free.
So the updates are free then?
Sweet I am pretty glad I have stuck with virtual dj. I had so many issues but after much trial and error everything has worked out great!! Thanks for the help guys. I can't wait till its available and finished!!
Depends....are you an experienced Pro User?
What has that got to do with anything...
Yes I am, thank you.
Is there any timeframe for a release of VDJ8? I know it'll be released when it's ready but is there any timeframe at all? Like expected in the next 2months ??
Nope, you just answered your own question .... it'll be ready when it's ready!
Keith
Obviously friend!! haha or I wouldn't have asked the question.
Definitely looks pretty sexy!
55%
