I don't remember there being a practical restriction - you can go lower than 1/8.
Posted Thu 10 Mar 11 @ 7:35 pm
Thanks SBDJ,but is it just me or it now shown in the default skin? Is it posibble in a future release that lower loops can be added? 1/12, 1/16?Haha,thats way too low anyway so thank you vdj team.
Posted Thu 10 Mar 11 @ 8:36 pm
ummm... installed the update and my mappers are not working. I have the radius 3000 and it magically isn't working anymore. It's not getting recognized now. No problem in 7.0.2. any ideas
Posted Thu 10 Mar 11 @ 10:42 pm
thanks for the update but i now cant download any plugins it say that vdj is not installed on my laptop please help
Posted Fri 11 Mar 11 @ 1:14 am
You cannot get lower than 1/8 using half loop. You have to assign a keyboard or midi shortcut for lower values.
Example Loop 1/16 ...
action ..deck 1 loop 0.0625
Or replace loop_half with
loop 50%
It will get as low as you wish.
Posted Fri 11 Mar 11 @ 5:06 am
Thanks for fixing the bitrate with mac!!! LOVE THE NEW VERSION!
Posted Fri 11 Mar 11 @ 7:22 am
Definitely a problem with Windows. Can't use extraneous hardware. I think it has to do with msi
File.things keep saying to install the softeare first because it cant find the program. Please post the last version up for download. I need the last version back again until this is fixed. If its something I'm doing please shed some light.
Posted Fri 11 Mar 11 @ 8:43 am
Update your OS (Windows) first, and re-install.
Posted Fri 11 Mar 11 @ 10:10 am
Did that and no help there. Did this work for anyone else.
Posted Fri 11 Mar 11 @ 2:23 pm
Thank you for the new update.
Posted Fri 11 Mar 11 @ 6:41 pm
Very good update; VDJ best DJ software. I just played at the famous Greenhouse Club in NYC with the MC6000 and VDJ 7.03 everything went smooth. VDJ for life.
Posted Sat 12 Mar 11 @ 9:22 am
Yay, didn't need to dig out my serial number after applying this update, thanks again for the free update :) [Note: this creates a new set of Start Menu shortcuts in a "VirtualDJ" folder rather than the traditional "Virtual DJ" one].
Posted Sat 12 Mar 11 @ 3:08 pm
Seems like another awesome update guys.. thank you!
I also noticed a few more effects in the Mac version.
I never had problems before but now this thing is just sharp (for lack of a better word).
Awesome!
Scott
Awesome!
Scott
Posted Sat 12 Mar 11 @ 7:22 pm
THis update has screwed the use of my playlists.
I have hundreds of them in subfolders within the playlists directory in VDj and every subfolder now just says desktop with a + sign and none will open.
Was fine in 7.02 but 7.03 on Windows 7 it happens
Posted Sun 13 Mar 11 @ 7:31 am
Same problem for me
Posted Sun 13 Mar 11 @ 3:18 pm
Cant Install any effects now since 7.0.3. Thinks that VDJ is not installed.
Posted Sun 13 Mar 11 @ 5:54 pm
Again.... effects and mappers not working.
Went back to 7.0.2 and all is well. Is this an issue with many others or what is the story here.
Posted Sun 13 Mar 11 @ 9:05 pm
I also have a problem, In the history tab, I have previously renamed the tracklist to what the event was, ie wedding, engagement, corporate event, but since the update, I cannnot rename. It says the tracklisting folder doesn't exist ? Yet, when you go into folders, tracklisting, you can double click to re-name ??????????????
Posted Mon 14 Mar 11 @ 9:59 am
If you have a custom definition file from a prior downloaded mapper install or from the American Audio website - then remove the file from the \Documents\VirtualDJ\Devices folder.
Have tested the Radius series units here and they recognize just fine.
Posted Mon 14 Mar 11 @ 6:36 pm
Do not understand 'why' this would happen. We did not change any code related to the tree browser. But, I have recreated your issue.
For a temporary work around - please create a 'Favorite' to the \Documents\VirtualDJ\Playlist folder and uncheck the 'Show Playlists' option in the Config -> Browser tab. Sorry for the inconvenience.
Posted Mon 14 Mar 11 @ 6:42 pm
