Will Any Soundcard that is ASIO and has 4 inputs andd 4 outputs work????????????
Posted Fri 22 Jul 05 @ 5:33 pm
Yes all soundcards can work with VDJ.
The number of input/outputand the ASIO bility doesn't change anything.
Posted Fri 22 Jul 05 @ 7:14 pm
Does the soundcard need 4 inputs and 4 outputs? Also, does it need to have ASIO capabilities?
Posted Fri 22 Jul 05 @ 9:56 pm
If you expect to yse timecoded vinyls or CD you need an ASIO soundcard. If you don't expect to use them you don't need it.
The number of input/output depends. You need at least 2 outputs (deck A & B). It's cool to have a third one for the sampler and one for the headphone.
Posted Fri 22 Jul 05 @ 10:41 pm
will i be able to plug in my headphones to the mixer, and use the headfone crossfader?????
Posted Sat 23 Jul 05 @ 3:40 am
That's your choice. You can plug your headphones into your mixer or into your soundcard and use the VirtualDJ settings.
Posted Sat 23 Jul 05 @ 3:52 am
but will it work witht the mixers crossfader?????
Posted Sat 23 Jul 05 @ 3:53 am
Yes if your headphones are connected to your mixer you can crossfade between each channel you want.
Posted Sat 23 Jul 05 @ 3:54 am
so to use turntables, and a mixer, with tcv's i need how many out puts, and inputs?????????????????????????????
Posted Mon 25 Jul 05 @ 10:10 pm
hey brennan how many turntables are you planning on using?
Each turn table runs in stereo right? A left and right - 2 plugs.
So two (2) turntables X 2 = 4 inputs.
Need it be said any clearer?
Posted Mon 25 Jul 05 @ 11:07 pm
ok just checking, and ya two turntables,
Posted Mon 25 Jul 05 @ 11:12 pm
