Fist of all I will like to say that VDJ is an excellent and the best dj software out there. This is why I decided to purchase the program.
Anyway, I'm trying to make a dll file for effects but since this is very complicated to do, I need an existing file to visualize how this works. How can I open an existing file? What program do I need to do this?
Your help will be apreciated.
P.S; I have look already in other sections of the forum and also downloaded some examples like .h,.cpp and microsoft visual net but still I cant get it to save as Dll or even open one. Pardon my little programing skills.
TX
VNZ
TX
VNZ
Posted Wed 25 May 05 @ 9:24 pm
Hi and welcome in this amazing community;
You're that's en excellent ... and probably the best PC-DJing software.
Editing a .dll is not the solution (nearly impossible).
You have to program a plugin.
If you have .net, try the Effect SDK: http://www.virtualdj.com/support/developers/effects.html
Can you program in C/C++ ?
Posted Wed 25 May 05 @ 9:27 pm
If you can program a little, check this topic: http://www.virtualdj.com/forum/display.html?topic=11010
Posted Wed 25 May 05 @ 9:28 pm
Thanks Clax. I can do little programing if you can say that. I already got to those links you posted. My thinking of a dll file was trying to open it like an XML file in skins which I can do and was able to learn to work with them and I think I can probably make my own skin now(xml with bitmap). But I guess Dll is more complicated than that and either I'm going to have to learn to make them from scratch or I will leave it to the experts.
So you are saying that once a C++ project is saved as an dll it cannot be opened back and be edited?
VNZ
P.S: All you programers/skinners can do some awesome work. I like the sampler manager, shaker beats and others. TX
VNZ
Posted Wed 25 May 05 @ 10:00 pm
No a .dll file (dynamic library linker) is a compilated file like an executable file (.exe)
c file (.c and .h) or c++ file (.cpp and .h) => compilator => .dll
Posted Wed 25 May 05 @ 11:07 pm
So with .net you create a new project and choose virtualdj pkugin by using the SKD installed.
Then when treatment is done you create a solution which will be a .dll file.
Posted Thu 26 May 05 @ 9:43 am
This is going to take some time to get!!!.
I'll work on it and see what results I'll get.
Will post later if I need more help. Thanks for the tips....
Posted Thu 26 May 05 @ 2:25 pm
You're welcome.
Posted Thu 26 May 05 @ 3:28 pm
hi this is cool stuff
Posted Mon 06 Jun 05 @ 6:07 am
So please reya_dis, if you like this software... don't crack it!
Posted Mon 06 Jun 05 @ 8:50 am
Hey Clax:
Man I have been working on this for long time and still can't get this. My wife is starting to get upset, dedicating too much time to VDJ. Anyway, I believe I'm close to at least reproducing the existing flanger plug-in and that way I will know how this works better.
The problem I'm having is getting a .dll solution. As per previous posts/links, I opened an empty proj. then I saved the .h and .cpp files provided in there and try to compile to create a solution and I get an error message saying I'm missing windows.h files. I'm using Visual C++ 2005 express beta edition (Download trial). Also I tried to download a source code but I guess thats restricted for some users only. I still believe I can do a plug-in if I just get little more direction and help on this.
What ever you can think of that I can use in addition to the other info you already gave me I will apreciate this. For ex: Am I using the right program for C++? If not, where can I get one? Can I get a simple completed source code that I can use to do my .dll and learn from it? I know, this sounds like cheating, but thats the only way I think I can get this. This is the way I learned to work with skins, by editing an existing xml and bitmap file.
Anyway, see what you think and let me know if I got a chance.
P.S: If I could only make at least a simple plug-in!!!
Thanks, again.
VNZ
Thanks, again.
VNZ
Posted Fri 10 Jun 05 @ 11:15 pm
well in the .cpp file you write:
#include < windows.h >
in fact windows.h is a library (an include) installed with your compilator (with others file in the same way) so visual c++ 2005 express should have it. I don't understand why
Verify your selected dll with windows standard inluded files or something like that. I didn't test visual c++ 2005 yet but i think soon
Posted Fri 10 Jun 05 @ 11:51 pm
The "#include < windows.h >" is in the cpp file, But I still get the failed message. Let me look in the visual 2005 folder see if I find anything like you said.
Posted Sat 11 Jun 05 @ 12:14 am
In fact i have just noticed the software is not finished so that's the reason why you can't select a dll project directly
Look here to see if your project in visual C++ 2005 express is well:
http://www.virtualdj.com/blog/djcel/?category=2
=> "Project" => "Properties"
Especially verify:
* "Configuration Type: Dynamic Library (.dll)"
* "Use of MFC: Use Standard Windows Libraries"
Especially verify:
Posted Sat 11 Jun 05 @ 1:22 am
Thanks Djcel for the config setup.
This is what I did: I created a new win32 proj from existing code. Then I pick the destination where vdjdsp2.h and flanger.cpp are located then proj is created, change config setting like what you have and then when I try to build a solution I get this:
1>Compiling...
1>Flanger.cpp
1>.Flanger.cpp(2) : fatal error C1083: Cannot open include file: 'windows.h': No such file or directory
1>Build log was saved at "file://c:Documents and SettingsOwnerDesktopJOSE'S FOLDERflangerBuildLog.htm"
1>flanger4 - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Ok where is the windows.h and math.h in the flanger.cpp file? This is what it can't find.
What the heck I'm doing wrong?
Thanks again
Vnz
1>Compiling...
1>Flanger.cpp
Thanks again
Vnz
Posted Sat 11 Jun 05 @ 4:03 am
If possible, can you show me step by step on how to create proj/solution? You can call it Plug-in for Dummies.
Sorry for all the ?'s.
Once I get this I'll be ok.
Posted Sat 11 Jun 05 @ 5:03 am
In fact windows.h and math.h are standard windows libraries so they should be with Visual C++ 2005
I have Visual Studio .net 2003 with all the files usefull: windows.h calls others files and so on...
C:\\Program Files\\Microsoft Visual Studio .NET 2003\\Vc7\\PlatformSDK\\Include
These files aren't with visual c++ 2005 beta and i find this beta is not really well: it still lacks a lot of things
install dev-c++ , i's free and this compilator has these files
Posted Sat 11 Jun 05 @ 5:24 am
vnz161820:
be sure that you include < windows.h> and not "windows.h" (same for math.h)
Posted Sat 11 Jun 05 @ 9:26 am
Ok this is what I did.
Downloaded dev-cpp(Now I got windows.h and math.h), Created empty proj, included vdjdsp2.h and brake.cpp then compile it and I got different errors in different lines.
Djcel: I sent you a prt screen picture of the errors to your MSN e-mail if ok.
See if my proj is set ok. I'm using the files from the effect SDK plug-in page (did not change anything on them).
Do you have something else I can base my 1st proj on.
This is it, If I cant get this in the next day I'm done.
Thanks.
VNZ
Thanks.
VNZ
Posted Sat 11 Jun 05 @ 3:37 pm
I have the same issue when compilating with Dev-C++ and i don't know why. Maybe the linker editor. I will have a look in the makefile:
it doesn't accept or find VdjDsp2.h whereas there is no issue with visual c++ .net 2003
Posted Sat 11 Jun 05 @ 6:47 pm
