Hi Everyone.
I have just bought this mixer does anyone here use this with Virtual DJ and if so are there any problems. I am now saving for the denon HC4500 I hope that it works with this mixer again some help with this would be great. Off to work will check back later this afternoon.
Posted Wed 29 Apr 09 @ 3:37 am
Speak to SBDJ - not sure if he has that model but he definately has an ECLER mixer he uses and loves it.
Posted Wed 29 Apr 09 @ 3:55 am
I use an Ecler EVO 5, along with either the HC4500 and/or timecodes.
I'm not aware of anyone mentioning anything wrong with the Nuo however.
Posted Wed 29 Apr 09 @ 4:24 am
DENON DN-S3700 CD/MP3/USB PLAYER
Will only need 1 of this unit suffice for a setup of I need to have 2 ???
Posted Wed 29 Apr 09 @ 6:02 pm
I have just bought along with my ecler mixer a Denon HC4500 and got it at this price including vat and delivery £359.00 now i'm looking for a flight case to hold the mixer and the HC4500 anyone got any ideas the mixer is 4channel the same size as the djm series i think. some links would be great
Posted Thu 30 Apr 09 @ 9:35 am
Hi Everyone.
Need some help with the ecler Nuo4. How do i get the crossfade to work within virtual DJ i have installed the ecler cd that came with the mixer and it is connected to the laptop, everything seems to be working as I have monitored the midi signal from the mixer to the laptop. Any help on this would be great.
Posted Sat 02 May 09 @ 3:14 am
If your laptop is recieving the MIDI signal, then it should be easy to do:
Open VDJ and go to Config > Remote Control
Right click on General MIDI and select Activate
Right click on General MIDI and select Config
Click Add
Select video_crossfade (assuming you just want to control video fader in VDJ and mix audio on the Ecler)
Move the crossfader and value should appear where it says {autolearn} at the top
Click OK three times
Enjoy :)
Click Add
Enjoy :)
Posted Sat 02 May 09 @ 5:43 am
Thanks Scott.
Will give it a go later today. Will this also let me crossfade the music as I do not use it for video
Posted Sat 02 May 09 @ 6:10 am
If you're using the Ecler to mix with External Mixer mode in VDJ, then that will be handled by the Ecler - you don't need to even MIDI map the crossfader if you're not doing video.
Posted Sat 02 May 09 @ 11:56 am
