Topic: Urgently Need Help Connecting CDJ1000 With Hercules RMX using VDJ
I will like to connect my Hercules Rmx(Sound Card) with my CDJ1000 or any CD Player and Mixer used in a Club.
2. Do i have to press play from the cdj after inserting the timecode cd?
3. Do i need to set anything from my vdj?
Can someone Please help me with full instructions on how to get this well done.
thanks.
Posted Mon 29 Dec 08 @ 11:46 pm
thanks.
Havent seen anybody used the RMX as a Timecode Box so lets not knock it. Its predecessor the Hercules MK2 was extremely crappy at TIMECODING.
Click on the following link and see if this will assist you:
http://www.virtualdj.com/wiki/TimeCode.html
streaming_DJ
Thanks alot for your quick response, but this has answerd only my No.3 Question.
Looking forward for more step by step instructions.
Thank you once again streaming_DJ.
Bless!
djflo1604 wrote :
streaming_DJ
Bless!
I knew the VDJ website had some blogs with timecode setup, maybe the admins could re-up this and as I stated before, this was the MK2 Hercules.
I did a little research for you and persons stated that it wont work.
I would suggest you get this unit.
NATIVE INSTRUMENTS AUDIO 8 DJ
Top FeaturesProfessional 96 kHz, 24 Bit Audio Interface. Ultra high quality Cirrus Logic™ AD/DA converters
Aluminium cased, super-robust, mobile design (slim size) specifically for DJs
8 hi-gain outputs (RCA)
8 inputs (RCA), 2 optional phono preamps with high impedance input mode
1 alternative microphone input with input gain control and input level meter (XLR)
Headphone output with visual level control
Low latency ASIO™ / CORE Audio™ / DirectSound™ driver.
USB 2.0 bus powered
MIDI I/O
Over 20 individual channel status LEDs for instant status monitoring and signal chain error detection
Compatible with any digital to analog DJ set up, such as TRAKTOR PRO
Includes full version of TRAKTOR 3LE with integrated Beatport music store access
Recommended retail price: €399 / $449
